make sure everything is tight. put some muscle on the wrench... you should be good. i dont have shims on my car either but the brakes dont rattle.Originally Posted by islandG
i have recently intsalled my hawk brakes and powerslot rotors. and i have been hearing some rattling sounds coming from my brakes and it stops everytime i press breaks so something has to be loose. i didn't put any shims, so i dont know if that is the cause of it. i put so brake lubricant directly on the back of the brake pad. could someone help me
The island G
n3oAcid24 = 01' Galant I4
Make sure the dust shield is not loose. See if you can wiggle it around.
the dust shield is tight. i believe the sound is coming from either the rotors or the pads. is it bad if i put the brake lubricant on the pads instead of the shims
The island G
