Thread: do eclipse shocks work on 8g?
Showing results 1 to 12 of 12
    does 95-99 eclipse kyb agx, fit on a 01 gtz?
    thanks for the help guys, and for the record i did search and i couldnt find anything on it, and i need to know before the auction ends.
    05-25-2006
    New York City
    1,028
    I believe only 3g eclipse shocks work on your 01 gtz
    2000 Galant ES = Daily Driver
    4,455
    Sleepervr-4 is correct. Only out of a 3g (00-04) will work
    Jason - - cofounder of TGCNY
    2001 Galant ES
    thank you so much!
    04-10-2005
    NYC
    3,695
    Quote Originally Posted by mrjaydeeone
    00-05
    4,455
    Quote Originally Posted by fatal1
    00-05
    that's right my bad :oops:
    2001 Galant ES
    are the eclipse ones identical to the galant ones? because i heard someone say that the eclipse ones wear out faster or somthing on the galant and you should spend the extra money to get the galant ones, is this true?
    Quote Originally Posted by dknight3
    The struts are the same one won't wear quicker than the other.
    I was lookin at gettin some off a 00-05 eclipse. But why are the part numbers different for the struts if they are the same?
    Like kyb gr-2 rear for galant=341293, and eclipse=341164
    You would think they would be the same part number if they were identical right?
    i just today put in springs for a 01 eclipse eibach think they 1.5-1.6 fit fine not as low as i thought it was goin to be,but there is no more body roll and its a night and day difference in handling.
    11-13-2007
    -OKC-
    3,970
    The rears will but not the fronts.
    So the AGX's for the 3G will work for our 8g's???????? FML i just bought a set of GR-2's!!!!!!!!!!!!!!
    1999 North Star White V6 8G
    2003 Yamaha R6
    2008 Lancer Evolution X
    The Original FACTION from the BGR Days
    First Founder of TGC Florida 2002-2005
