Thread: Just gotta mono amp . .
Showing results 1 to 13 of 13
    i bought a mono amp a while ago from a kid who had it hooked up to 2 12's. but i know longer talk to him and i dont know how to do it. how do you hook a mono amp to 2 subwoofers?
    connect the two positives from the subs together than to the amp. same with the negatives.
    basically you twist the matching wires of the sub together and then connect the singles to the amp
    09-10-2003
    Charlotte, NC
    4,463
    waaait wait wait, first, what is the lowest ohm load can the amp handle?
    second, are the subs dual 4 ohm, single 4 ohm, dual 2 ohm, single 2 ohm, 8 ohm??
    you cant just hook subs up and let them play, stuff starts on fire like that.
    After answering those two questions, you then use one of these diagrams to hook up the subs:
    http://www.crutchfieldadvisor.com/le....html?view=all
    you want to run the amp at the lowest ohm load its capable of for best results.
    ^^^ X2
    FOUNDER OF THE EVO WING ON A G GROUP member #1
    i dont know ,the amp is a kenwood KAC-81520. I cant find the specs on it,all i know is its 1500 watts rms but know idea about the lowest ohn load. the speakers are the alpine Type-R SWR-1242Ds. They are dual voice coil 4 ohm speakers. anyone know the specs of the amp though?
    Quote Originally Posted by cbuster77
    it's a KAC-8152D ftp://inform.kenwoodusa.com/manuals/KAC9152d.pdf
    specs on page 7.
    04-10-2005
    NYC
    3,695
    i would suggest if ou dont have the slightest clue as to what your doing that you take it to a shop
    09-10-2003
    Charlotte, NC
    4,463
    appears to be 2 ohm stable, so if u got two dual 4 ohm subs u wanna wire like so:
    your amp wont be running at full power but it will sound good nonetheless, its your only option, do NOT wire down to 1 ohm
    ok so if i hook it up that way the amp will only be pushin out the 300w rms right?
    u might blow the channel i did that with a 2 channle once
    09-10-2003
    Charlotte, NC
    4,463
    Quote Originally Posted by WhiteGTZ01
    that makes no sense at all...
    but anyway, yea you would be putting out 300 watts at 4 ohms.
    aight man thanks for your help,after im done ill let you know how it goes
    09-10-2003
    Charlotte, NC
    4,463
    alright good luck
