check that your dust shield/ backing plate is not touching your rotor.
most likely it is.
if it is, simply bend it back.
and the sound will go away.
i presume the sound is made weather r not the brakes are being depressed?
So I finally got around to installing my powerslot rotors and pads.....
Got the brake lines bleeded and flushed
Great stuff.....
But the problem is.... There is a loud grinding sound whenever I turn....
anybody else have this problem..... or do i just have to wait for them to break in??
most likely it is.
naw.... just whenever i turn
the lug nuts torque to spec and torqued in a star pattern?
