Thread: Turn Signal BULB LEd's
Showing results 1 to 20 of 28
    09-20-2004
    Queens, New York
    602
    Can i change my turn signal bulbs (1157) to LED 1157?
    http://cgi.ebay.com/ebaymotors/1157-...98379142QQrdZ1
    WOuld i need a load resistor kit? OR can i just do it plug and play?
    You do need a load resistor and other stuff unless you like the excessive blinking/ constant busted fuses.
    09-20-2004
    Queens, New York
    602
    What other stuff?
    Experienced TGC Member rez887's Avatar
    06-10-2005
    Dallas
    1,236
    It's pain in the a$$.
    01-07-2006
    707
    I got LED bulbs in the rears right now. I like the fast blinking, lol they are bright as hell. I've had them in there for like 2 months now and nothing. :D
    i have led switchbacks in my front right now in 1157 (parking white, signal amber). u need a load resistor. simple to install (just need pliers and some wire taps). took me all of 2 minutes to do... all my lights work like they were meant to from factory.
    http://raniworld.com/raaa/switchback.qtl
    these are mine....where can i find a switchback?
    09-20-2004
    Queens, New York
    602
    Ok just wonder im looking on ebay for tail light LED bulbs. Is the 2057 bulbs the same as the 1157? Are they any different cuz on ebay thye are making it seem like they are the
    switchbacks:
    http://autolumination.com/switchback.html
    don't forget load equalizers unless you like fast blink.
    09-20-2004
    Queens, New York
    602
    But that doesnt answer my question...are they the same size or no
    Quote Originally Posted by Cheekz185
    2057 and 1157 have the same base. the difference between the two is that the 2057 runs on a lower wattage on low filiment than the 1157 bulb. but yea, that wouldn't matter much on a led bulb.
    that's because i wasn't answering your question... i was answering one of the questions before yours.
    here's the answer to your question:
    Quote Originally Posted by [url=http://faq.f650.com/FAQs/BrakeLight.htm
    Brake Light FAQ[/url]]
    ALL the bulbs below are Ba15d (dual contact/dual filament) INDEX BASE (axially offset pins, one direction only). External dimensions are identical. Physical differences vary only in terms of construction materials. The bulbs below differ only in terms of the lamp filaments/wattage/output/expected life, as noted:
    BULB# # Voltage Amperage/Filament MSCD Hours/Watts
    1157 12.8/14 2.10/0.59 32/3 1200/5000
    2057 12.8/14 2.10/0.48 32/2 1200/5000
    MSCD is "Mean Spherical Candela", or "candlepower".
    notice the numbers i put in bold. the only difference between the 1157 and the 2057 is that the dim filament of the bulb is dimmer on the 2057... what that means is that the contrast between parking and brake/signal is higher for the 2057. as far as LED versions of these 2 bulbs, the difference is nominal.
    how do u load the resisters 2 stop the fast blinking??? wen the hazards are on its normal? Why?
    09-20-2004
    Queens, New York
    602
    the load resistors have 2 wires on them, just connect them to your turn signal wires. And you are good to go. You have to connect them to each sidee
    connect it just like a fuse? (Bridge them) and where can i get resistors
    whats it called..... eq's? and what would u recommend adding 50watt? 25watt?
    09-20-2004
    Queens, New York
    602
    50watt if u are goign to put leds in both the tails and heads
    is there a tutorial or something on how to wire up the load resistors for the LED turn signals. I want to change the front (switchback sounds cool for the front) and rear turn signals as well as the reverse lights and the brake lights when I eventually put on my JDM tails. would I need load resisters for those lights as well?
    Quote Originally Posted by Armageddon Sunset
    u only need the load equalizers for the signal circuits. if you plan on doing front AND back signal LED's, get (2) 3ohm/50 watt LED load equalizers; if you just plan on doing just the front OR just the back, get (2) 6ohm/25 watt LED load equalizers. http://autolumination.com/equalizers.htm
    here's the wiring schematic:
