Thread: What the hell??? Blinking A/C Light
Showing results 1 to 15 of 15
    I was using my A/C last night when suddenly the A/C light on the dial began to intermittently blink on and off. My A/C also stopped working just the fan was blowing.
    This morning the A/C was working fine. Any ideas what the hell just happened??? :shock:
    330ci
    Two things maybe wrong"
    1. Was it raining hard that day? The outside vents suck in air unless you use the inside vents. If there's little air from the outside then the a/c light blinks indicating you need to switch to inside vents. This also happens when the air is humid after a rain storm.
    2. The blinking light indicates your A/C refrigerant is running low. Fill it up with R-134a.
    I think it was problem #1
    Quote Originally Posted by G-spot
    Yeah, it was fucking down pouring! This makes sense because if I remember correctly when you use the defroster it only uses the outside air, correct? I tried to use my defroster when it began to rain.
    330ci
    blinking light signifies only one thing.
    the belt was slipping (or it THOUGHT it was slipping).
    01-24-2005
    DFW/Stillwater
    2,752
    my belt slips everytime it rains or its cold and my a/c light has never ever blinked
    then your AC belt isnt the one thats slipping.
    This happened to me yesterday. I drove the car 10 miles to church, then 15 miles to my parents and it worked fine the whole time. When I left to go home it worked at first but did start blinking after about 2 miles and the a/c stopped working. Later that night it seemed to be working normally when I started the car and ran it for 5 minutes. The weather was dry and around 85-90. So is the problem a belt problem or a refrigerant problem?
    Quote Originally Posted by keithert
    It's gotta be the belt slipping. A problem with the refrigerant won't make the light blink.
    the belt could be possibly really warn too. you should check it out
    02-28-2005
    Metropolis
    3,540
    Keithert when was the last time you changed your accessory belts?
    10-24-2003
    1,432
    Or the clutch slips, thats what mine does, all the time, I think the compressors locking up, but the clutch is worn out and slipping instead of slipping on the belt.
    www.gooichimotorsports.com
    Quote Originally Posted by 6G72gearhead
    is the clutch in a compressor easy to change?
    2011 Camry- 202 miles- just picked up 9/10/10
    2008 Pontiac G6- 26,065 miles- traded in
    1999 Galant ES- 91,846 miles- long gone
    01-19-2007
    Lyndhurst, NJ
    3,473
    You might as well just change the whole thing...
    10-24-2003
    1,432
    You need a new orface tube and dryer everytime you open up an a/c system. I'm more of thinking about removing it alltogether.
