Thread: Best way to wire the 7G for subs in the trunk
Showing results 1 to 6 of 6
    I used to own a 97 ES and had the sub power wire nad RCA wires running under the carpet along side the doors. I did not really like it like that. I just purchased a 98 Es and i am looking to put the subs back in and was wanting to know the aestetic way to wire the cables. Thanks
    05-25-2006
    New York City
    1,028
    I ran the power wire from the drivers side following the harness under the door jams and the rca cable on the passanger side under the doof jams. There is a white plastic thing in there to run wires. Its best to keep the power and rca wires apart so you don't pic up any sounds from the electical current going threw the power wires.
    2000 Galant ES = Daily Driver
    and when you get to the trunk how did you route it into the trunk to keep it "low Profile" i want it to not be seen at all anywhere you know what i mean
    05-25-2006
    New York City
    1,028
    you keep folowing the harness for the backup light and brake lights.
    Thank now i was wondering if anyone had suggestions for mouning the amp in the back on the back seat.
    my 4 chennel is mounted to the back of the back seat, just drill it to it.
