Thread: What type of amp
Showing results 1 to 15 of 15
    What type of amp
    I am going to be powering 2 12" subs both with a 1000w max rating and DVC . I was wanting to go 2 channel but they seem to be more money. I am wondering how big a mono amp would need to be to push the subs I am looking for good bass at the cheapest price. :? :? :? :?
    Mono's tend to be more expensive actually. If you have 2-DVC subs also you would have to find a 1-2 Ohm stable amp which is more expensive. A 2 channel amp rated for 300-400 watts each channel would be ideal. How much you lookin to spend? It depends on what type of subs you have too and the RMS wattage, not the peak wattage they are rated for. Some more info would be helpful.
    8G Galant GTZ-juiced, 275 hp
    1G Eclipse GSX-pushin 400 whp-09/22/06 12.33 @ 113mph
    The best of both worlds...
    here are the specs for the sub:
    Volfenhag Model #ZX4712DVX
    12" Dual Voice Coil Woofer
    * Magnet: 160 oz. Double stacked Ferrite
    * Frame: 5 spoke Die-cast aluminum basket
    * Cone: Reinforced aluminum curvilinear
    * Surround: Oversized buytl rubber
    * Spider: 2 Flat ultra excursion
    * Power handling: 500 watts RMS, 1,000 Watts max
    * T Yoke: Industrial Chromed Hex bolt retained, Bumped and Vented
    * Double damper magnetic motor assembly
    * Cooling: Double Vented (T Yoke and Motor Side vents)
    * Voice Coils: 4 Layer Dual 4 Ohm High Temperature black Aluminum
    * Voice Coil Diameter: 2.2"
    * Nominal impedance: 4 ohms / per coil
    * DC resistance (Re): 3.2 ohms ea. coil
    * Frequency range: 20 Hz-1.1 kHz
    * Fs:30 Hz
    * QTS:.526
    * QES:.614
    Hope this helps
    09-10-2003
    Charlotte, NC
    4,463
    http://cgi.ebay.com/AUTOTEK-MM1000-1...QQcmdZViewItem
    that should do it
    basically what you are looking for is a 1000 watt, 1-ohm stable amplifier to power those
    Then wire both subs like this to the amp (crutchfield didnt have a 1-ohm diagram since its rare)
    When you wire both subs like this it will give you a 1 ohm load, pushing the amp to max capability
    well what about a 2 channel legacy amp would that work?
    your better off with a mono amp
    FOUNDER OF THE EVO WING ON A G GROUP member #1
    09-10-2003
    Charlotte, NC
    4,463
    Legacy is garbage.... you must be on a tight budget?
    If so I recommend:
    http://cgi.ebay.com/NEW-1000-WATT-LA...QQcmdZViewItem
    I got a Lanzar amp, working pretty well
    With this amp you have two options: wiring each sub to its own channel at 2 ohms per channel and get 400 RMS watts to each sub:
    Or you can wire both subs together at 4 ohms NOT 1 OHM and bridge the amp to make 1000 watts max:
    but if you have enough money , buy MMATS amps they re one the best
    JDM front covension Old style vr4,18"axis black seven mod,clifford alarm,egr rear window visor,kenwood unit 7"screen DVD,two tones paint job,3G strut bar , HID's.
    yah i am short on money, i jsut got out of the Army and moved back to MA and i got a family to support so it is hard to "pimp" the G. But it needs to be done. :D :D :D :D
    09-20-2004
    Queens, New York
    602
    I agree with serstylz...autotek amp are good for the money! I would go with that amp!
    now that i have the amp figured out what guage should the power wires be and where can i find a wiring set cheap
    You would be fine with 4 awg. complete sets with fuse and holder/connectors are on ebay for cheap. Best place to get all the stuff in one package.
    09-10-2003
    Charlotte, NC
    4,463
    Quote Originally Posted by SinSere
    Yep. Just dont buy from eBay users named Judysdeals or cmttrading, they usually have the cheapest 4 gauge kits but most likely it will never show up, or it will arrive in a month and a half
    You don't want the cheapest kits on there. But there are real reasonable packages. You can tell by just going through them which ones are cheap cheap vs. just cheap ones. Always look at ebay feedbacks and quantity of business they do.
    I have Ma Audio 1-gauge power wire, distibution block and ground wire laying in my car and 2-100 amp fuses. For sale anyone (shipping may be high heavy wire)
    SportBike Powder Coating
    "Not Just Bikes"
    [email protected]
    Photos
    http://www.photobucket.com/sportbikepowdrcoating
