Thread: 40" rims
Page 3 of 3 FirstFirst 123
Showing results 41 to 57 of 57
  1. #41
    North Bay...NorCal
    2,552
    I was just thinking the same thing at this very second! I cant even see the damn brakes!
  2. #42
    it has brakes!? :shock:
    i dont even see brake lines, you know that that cant be driven around much
  3. #43
    Experienced TGC Member AVERAGE's Avatar
    02-09-2006
    Raleigh,NC USA
    1,085
    The term "fucking ridiculous" comes to mind Im guessing that's just a show piece.
  4. #44
    Re: 40" rims
    Quote Originally Posted by surycdrol
    Quote Originally Posted by mrjaydeeone
    Have fun stopping with all that rim, and those little ass brakes
    looks liek he has drums :?
    FOUNDER OF THE EVO WING ON A G GROUP member #1
  5. #45
    talk about a fucked up gear ratio.
    that engine is going to be lugging in evey gear.
    not that i'd drive that car above 0 mph
  6. #46
    What size disc do you think it will take to stop that thing?
  7. #47
    15" +
  8. #48
    Quote Originally Posted by DOHCstunr
    Why?
    Those old chevy 350s (which is likely what it has) have plenty of low end power. The only issue is the gearing of the axles, but I suspect those are dana44s which can more the adequately handle something with that much rolling mass. It could also have a old strong chevy 10-bolt rear axle which also can handle turning those things easily.
    Not that I'd care to ever drive it, just stating that its easy with the right engine and drivetrain combo, even being unmodified.
  9. #49
    i just like that therre is no suspension whatsoever.
    the fabrication they did to allow for such an obomination
    involved nothing more than welding a bunch of steel so they woudl ahve clearance.
    no shocks, no springs.
    so gay
  10. #50
    so gay
    thats the wrong and cheap way of doing it, the right way(which ive helped on) is to get an actual truck suspension & spindals then you extend and weld innew metal in the control arms and trailing arms.. ... ill try to find a pic od the car i helped work on
    EDIT: I found a pic, the car right next to it is a s-class benz just to give you an example of how high it is.. it is lifted 6inches and it has 26's on it
  11. #51
    Thats ridiculous its a waste. Cause he probably ended up payin around 8k to do all that or so, considering if those rims are any good im sure it was at least bout 4k or more for them. And to get all the fab work and new axles cause they usually by hummer axles and hook them up, (only now cause my friend tried to do it once). Waste of money.
  12. #52
    Quote Originally Posted by bmxmike
    I'll give you money if you can find a set of new 26" Gianelle 5-holes with 305/30-26 Pirellis for less than $4000. I've never seen anyone get 26s for less than $6000.
  13. #53
    Hey, hey, maybe he just wanted easy access to the oil pan... :P
  14. #54
    Baltimore, MD
    2,848
    Without a doubt the most ridiculous waste of time and money to be posted in quite some time. Looks like shit, and undoubtedly drives like shit (if it drives at all). Easy to change the oil though What a dumbass....
    Chip
    (Paint Code: Porsche LC9Z)
  15. #55
    Eh...F*cker Is Pretty Damn Tall...
    Quote Originally Posted by G-spot
    On the side note, that purple 3G behind it is sick!!! :shock:
    Kid
    Saving People, Property, And The Environment From Such Dangers As Fire, Hazardous Materials, And The Grim Reaperâ„¢...
  16. #56
    ^ Was that a 3G or a figment of my imagination :shock:
  17. #57
    Xska55
    WOW! Im speechless, I personaly dont care to much for it but I do apprciate when people are always willing to put in the hard work and thought process to out do the next guy.
