Thread: 6a13 engine
Showing results 1 to 18 of 18
    6a13 engine
    Wich gearbox will fill an galant with engine code 6a13?
    you want a fwd box or 4wd drive box?
    98 LEGNUM 25-ST & 99 LEGNUM VR4
    CLUB VR4 - The Ultimate Resource
    i want a fwd
    umm sorry cant help much then,
    but the box from a 6a13 n/a sohc will fit,
    and so will the boxes from cars that have a 6a12,
    and the FTO gear boxes will fit,
    head over to www.clubvr4.com
    as we have a few FWD 6a13TT powered cars, and the 6a13 sohc fwd's
    and someone there will be able to help.
    i dont know the numbers for the fwd's as both of mine have been 4wd's
    from wich car can i get the 6a12 and 6a13 na sohc??
    a JDM 92+ galant, or 96+ legnum,
    WarmAndSCSI
    Would the transmission from a 6A10 ('92-'98 Lancer) also fit?
    i would assume so,
    as far as im aware all the 6A's share the same bottom end design,
    but i doupt it would be up to handling the power/torque of a 6a13 TT or Sohc
    hi guys, just wanted to know if anyone here knows the required number of liters of oil for a 6a13 engine. thanks!
    im planning to use 5w-30. would there be any problem with the internals on cold starts?
    4 liters from what I recall..
    OT.. Gly I didn't know you're also here :D
    thanks for the inform naurhtika03. btw, nice engine your have there. hows the fuel consumption?
    6a13
    thanks 6a13 for teh info. btw, what program are you using?
    6a13
    Quote Originally Posted by aki View Post
    Autodata 3.18
    thanks! i will try to look for that program. looks like its realy useful.
    ACan i install the headers from a 6a12 in a 6a13 engine?Will this fit?
    12-14-2006
    New Zealand
    823
    The 6A12 ones are more restrictive, why would you want to ?
    1995 FTO - V6 Mivec 200hp
    I only want to now it. Is it possible that the headers from the 6g72 fits the 6a13? Nobody has headers for the 6a13 engine.
