well you would need some other type of guage or meter to read it i would guess...
...know if your speedometer(and all other meters on gauge cluster) is the right reading? i cleared my needles a while back, they all work...but for some reason, i don't think they read the right reading...
Can you borrow a portable GPS from anybody? That's how I check mine.
nope...is there another way i can do it myself???Originally Posted by WarmAndSCSI
Mile markers on a highway. Maintain a constant speed between two mile posts and do the math.Originally Posted by o1naturalhigh
got an equation to go along with that??? not too good on math...Originally Posted by WarmAndSCSI
So you'll cover exactly 1 mile between the two markers. Set your cruise control (if you have it) or keep a constant speed as well as you can. Make a mental note of that exact speed. Then, count the number of seconds it takes you to get from mile marker A to mile marker B (this is 1 mile).
1 mile divided by the number of seconds it took you gets you miles/second. Multiply that number by 3600 (60 times 60) to get you miles/hour. Compare this number to your observed speedometer speed.
For example, say it took you 47 seconds to travel that one mile. 1 mile divided by 47 seconds is 0.0213 miles/second. Multiply that by 3600 and you get 76.6 miles/hour.
Hope that helps :D
thanks...i'll try tomorrow on the way to work...
so...besides a gps and this...what else would work, machine-wise???
if you look through the service manual, it will say how to make sure your gauges are calibrated. kinda tricky.
you can slap the car on a dyno and it can tell you how fast its going.
water temp gauge will tell you water temp. although the factory gauge doesn't tell you much anyways.
some obd-ii tools such as the scangauge gives out readings such as mph, rpm and water temp. just plug it in and it tells you the info.
that's what i was looking for...thanks pinoy...Originally Posted by pinoyesv6
is your car v6 or i4? if it's v6 there is a way to do it w/o any tools. i only know this because i paid attention to my stock gauges b4 i swapped 3 seperate times (SPEEDHUT protoype, GDI, AC S7) and had to recalibrate each time.
this works for V6's (not sure about the i4) assuming that your tires are near stock diameter.
1st gear runs to redline at 45mph.
lock your car into 1st gear and run to 45mph. your tach should be bouncing off the revlimiter at 6250rpm and your speedo should read 45mph; if it doesn't STOP and readjust (please don't try to make adjustments while you are driving). repeat until you have it. now go fill your tank. turn the car on and wait for a minute then put the gas needle at full and the temp needle at a hair under half way. clip the clear plastic back on your gauge cluster and screw the main bezel back in and you are done!
haha... just found this from 2002:
https://www.thegalantcenter.org/viewtopic.php?t=3899
Originally Posted by Reelax
its an i4Originally Posted by Reelax
ask someone w/ an i4 to find out what mph and rpm the car redlines in 1st gear... mods won't matter as the gear ratio will still b the same (unless of course they modified their tranny including a 5 speed swap). if you know those 2 numbers (redline and 1st gear top speed), you can calibrate pretty well w/o tools by follwing my directions above.Originally Posted by o1naturalhigh
someone correct me if im wrong, but i think those speeds are in the owners manual. or maybe the fsm. but i think its the owners manual. might want to look there.
Yeah, they are in the owners manualOriginally Posted by pinoyesv6
well...to let you guys know...my friend(that is a mechanic)...i asked him if he has that tool that does all that...he said yes...i borrow it tonight til tomorrow...bring it back for the pacqiao fight...
