Thread: Mitsubishi CAPS Part Lookup Application
Showing results 1 to 20 of 20
    WarmAndSCSI
    I know there's another thread here somewhere about the Mitsubishi CAPS program, but I figure I'd link to the latest version I could find (covers up to 9G Galants). You can use this application to pull up diagrams for almost everything on your car and then get part numbers that you can use at https://www.mitsubishiparts.com/oe_parts_catalog.html to get prices and even order the parts.
    I see requests for part numbers every now and then, so I figure this would help you all out. I use it ALL the time to cross-ref part numbers from different models when I go junkyard digging.
    You can download the program directly from here: http://www.stealth316.com/misc/wincaps-setup.exe
    EDIT: 100 MB! Dialup users beware.
    More info on it can be found here: http://www.stealth316.com/2-wincaps.htm
    01-19-2007
    Lyndhurst, NJ
    3,473
    Sweet find!
    Thanks! Need to look up some stuff too!
    WarmAndSCSI
    By the way, it's really big. Broadband highly recommended... :mrgreen:
    02-07-2007
    ORLANDO
    1,599
    great find man no more hastles with dealerships for part #'s (one guy actually told me he wasn't allowed to give it to me?wtf?) thanks man!!
    WarmAndSCSI
    Bumping this... too many people ask about this application. Make sure to get the update file too on the page I posted.
    10-24-2003
    1,432
    Bitchin'
    www.gooichimotorsports.com
    08-08-2004
    Las Vegas
    2,099
    i posted another file that had all the overseas cars too i'll see if i can find it again
    WarmAndSCSI
    Quote Originally Posted by underated
    Please merge this all together and sticky it if you get a chance, mods. It's a really, really valuable resource.
    Thanks!
    Member JDM4G64T's Avatar
    07-09-2007
    Fort Lauderdale, FL
    324
    Sweet find bro.....
    Car is sold, no more G.... Moved on to something a big more sporty.... lol
    08-08-2004
    Las Vegas
    2,099
    07-12-2007
    SoCal
    4,632
    I have a cable connection, only took about 10-15 mins. :D
    JDM Zenki Conversion
    10-24-2003
    1,432
    This seriously needs to be a sticky.
    12-14-2006
    New Zealand
    823
    CAPS is no longer used by Mitsubishi, they have gone to ASA, which you can update regularly. It's basically the same program, but is a bit more secure.
    1995 FTO - V6 Mivec 200hp
    Quote Originally Posted by Goku View Post
    any links???
    - If you've got nothing nice to say, what the hell is wrong with you!?!
    Caps again in case the other links doesn't work...
    You can download it from here: wincaps-setup.zip
    That is the parts lookup program that the guys behind the counter at the Mitsubishi dealerships use.
    From what I remember installing, just run the setup, and let it install into the c:\ drive. After that, I think there is also an update patch to get the latest info, and you just unzip it over the installed files.
    To use the program, you need a VIN code for the car you want to look up parts for - you could use the chassis code and other things, but its much easier to have the VIN code.
    www.edelhausrottweilers.com
    05-03-2007
    Socal/Central Coast
    3,803
    Thanks for the new link Jason! Unfortunately, CAPS doesn't work with my 64-bit OS :(
    01-08-2008
    Levittown NY
    2,786
    I have 64bit as well :(
    let me see if I can get it to work
    12-17-2002
    Sherman Oaks, California
    4,304
    where is the update?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    your link
    Thank sfo rthat. i a new to this i bought the car off my friend because he was afraid of his soon to be Xwife might wanted it. anyways i am sure i will get alot out of your link. I am looking for a rear brake drum to disc brake conversion kit. for my car? would you know where i can find this? thank you again.
