Originally Posted by Gladiator
it is a twist and lock. it will be hard man. just remember turn it left. and i think the bulb is a 194. i put a white LED light there a year ago and it looks good.
I want to switch my license plate light to LEDs but I have a hard time removing the light. Is it a twist and lock mechanism or what?
Also any suggestions on what kind of lights I should get that are bright and white.
Thanks
n3oAcid24 = 01' Galant I4
i used the bulb that goes to our third brake light becasue its all i had and it fit so i used that and its so bright!!! it lights up the road behind my car
I put a 194 LED in there and it's really bright! It's just twist..
194 (12 bulbs) LED should do the trick 8)
I remember the first time I took off the whole thing instead of twisting
Haha me too.... noobs
same here brovaOriginally Posted by pvu_rida
yah well.. mine doesnt work cus of some stupid reason.. any of u guys know if it has a fuse ONLY for it..
im thinking of just rewiring so it works... but i dont know how.. any suggestions.. i wouldnt mind it with an LED
04 Maxima SL in Bronze with Black leather
x2, put the white LED in there...looks kind of HID'ishOriginally Posted by Jeffylou87
2001 5 speed 4g64T
there was a thread about this a while back..lemme go find it
cool thanks for the replies, now I'm gonna get some LEDs!
edit: for our cars we only need one piece up in there right?
something like this would work? http://cgi.ebay.com/2pcs-T10-W5W-194...QQcmdZViewItem
Do you mean the bulb or the plastic case that it's in?Originally Posted by n3oAcid24
I was out there for 15 minutes and I couldn't get to the bulb.
My fingers hurt.
you open the trunk and reach inside the opening and you just twist the piece out that holds the bulb, swap bulbs twist and lock back in and voila.Originally Posted by Joe (G8)
or you can do what I did the 1st time when I didn't know any better. Just unscrew the plastic that covers the bulb and swap bulbs and replace the plastic
I unscrewed the bolt on the outside, but I couldn't get the plastic off.Originally Posted by mrjaydeeone
It's at night, so I couldn't see what I was doing, but it turns out that I was trying to reach through that tiny hole on the inside for the longest time until I realised that all I had to do was reach around.
I installed the PIAA 194 Xtreme White Interior Replacement Bulb and there's hardly any difference at all.
It doesn't light up the ground or anything.
What a waste of $12.95
Check out my last comment on this page.. it looks perfect!!!
https://www.thegalantcenter.org/view...675&highlight=
But does that fit in the clear plastic housing where the license plate bulb goes? or did u need to do modifications?Originally Posted by Three O Five 8g
I bought the lights I had linked in the earlier post. When I have them installed, I'll have pictures.
