Member
How to remove driveshafts on 7G Galant?
Help guys I desperately need to know how to remove the front driveshafts on my 1994 Galant V6.
I don't know what the hell to even start removing to get to the driveshafts? I've done plenty of MacPherson strut cars but this one is just baffling me. There are ball joints and suspension arms to africa!
Cheers,
Phil
Easy peasy. Remove whee. Remove end 32mm axle nut. Remove lower control arm from the chassis. Remove strut fork from lower control arm. Remove axle from trans. Pull axle out. Replace new axle the same way the old one came out.
Member
Removing the lower control arm, that would involve splitting the ball joint off the steering knuckle wouldn't it?
Member
Thanks to Seth for the advice - driveshafts are out!
