Thread: Cyclone Intake Manifold
Showing results 1 to 7 of 7
    North Bay...NorCal
    2,552
    When I go turbo....could this be used on the 64? Since we can use the exhaust side of the 63 I was wonderinf about the intake. What mods would need to be done? I know the cyclone was an ECI and I suppose I would have to run a different fuel rail. But question is should I even bother?
    it will only bolt up to a 6 bolt head,
    or a 2g 4g63t 7 bolt dohc head with a lot of port matching.
    the sohc manifold is differrent, and incompadable.
    but its a great device.
    i get more vacuum at idle, as well as at cruise,
    more vacuum = better mileage, more power out of boost.
    North Bay...NorCal
    2,552
    ah well...it was a thought. I saw one for cheap! I was gonna snatch it if it was possible. So really, the 64 dont have another option on the intake side huh?
    Custom!
    Quote Originally Posted by evil-G-nius
    saw off 3 sides of the plenum,
    have a large sheetmetal plenum welded onto the stock runners,
    of course port the shit out of the stock runners while you have the plenum off.
    you'll have a larger resevoir of air on reserve for the top end.
    you can also "acid port" your manifold
    Also you would need an ecu or a chip that is program to open the butterflies on the second set of runners.
    Signature wanted call: 1800-Darkkend
    <a>Take Better Photoshots Tips from the Pro's</a>
    Quote Originally Posted by Darkkend
    or simplly an rpm activated switch,
