Thread: finally some new replacement parts for the G
Showing results 1 to 8 of 8
    first is not really a part, just 4qt's of oil as im VERY low on oil right now
    2nd is some brand new denson brand spark plugs from auto zone
    and 3rd is some brand new duralast brand spark plug wires
    mitsumitsu aka luke9511
    shoulda saved money and bought a tripod for the camera hahaha j/k ;)
    well heres an update, those things didnt help much, still getting misfires and backfires and also there was oil on the old plugs and alot on the last plug on the far left, im hoping all my problems will go away once i get my new flex pipe and also see about getting some sort of cable that can hook up to my laptop and to my car and use some software to read the codes cause i cant find any place around here that can read the damn codes
    ^^that sounds like you have a worn valve cover gasket. The oil thats seeping out is a very clear flag. A flex pipe won't fix the leaking oil. Buy a valve cover gasket from autozone or advance autoparts. They are cheap and the job takes 1 1/2 hrs max. Then u need to get NGK spark plugs b/coz they are the best choice for our cars. Hopefully these will help with the leaking oil and misfires. Good luck
    7G SOHC 5SPD
    1.already replaced the valve cover gasket and orings and autozone didnt have ngk plugs and since i wasnt paying i couldnt get them if i wanted too :(
    Oil on top of the plugs where the wires go? Or oil on the bottum of the plugs. If its on top, then those o-ring gaskets are leaking. Whens the last time you changed the distributor rotor and cap?
    im not sure when they were changed uptill i got the car my unce was taking care of it, i also need to replace the oil pan gasket and one other gasket aswell
    ok the picture im posting is of the spark plug that had the most oil on it, it was on top of the spark plug where the wire went and i dont think the o-ring gaskets are leaking cause i replaced them along with the valve cover gasket
