Good find.. any trouble with hoses?
this is a cost effective upgrade if you're looking for a bigger radiator. the evo radiator fits with a few modifications, mainly, the way the fans mount. (a few zip ties will do the trick). i paid 100 bucks shipped for the radiator.
here are some pics. as you can see it's more than half as thick but takes up the same total amount of area.
Cali: Sig 3/28/2011
what kind of difference does it make?
mitsumitsu aka luke9511
you still have room for your condenser?
From which evo is this radiator? 8?
yesOriginally Posted by Strizi
more room in engine baywhat kind of difference does it make?
looks like you got to take the extention out of your upper radiator hose huh cali?
i assume you'll be ordering a new set soon enough.
looks good,
gotta love the extra capacity.
yup. that's one thing i was looking forward to. i'll order a new one soon. :)Originally Posted by DOHCstunr
Cali: Sig 3/28/2011
Noel, the EVO radiator fit too without needing to cut the edges to fit the JDM heads? Thats the way it looks, I didnt put my headlights in yet, so I cant tell if its gonna hit or not.
4G64/63T
AEM EMS
Do you guys know of a half size radiator that will fit the galant? i havent been able to test fit any that are made for honda's... i always wondered if the evo radiator worked thanks for posting this up Cali
i didnt even bother to check to see if it fit without cutting, i just went ahead and cut it anyways.Originally Posted by Stewi
and yes, the condenser wasnt a problem.
Cali: Sig 3/28/2011
I had an Ebay civic radiator in my car, its not a direct bolt on, you need to relocate the top mounting bracket more towards the center of the car on the radiator support and you need to fabricate a lower mount on the passenger side. Its not really hard to make it fit, it took me a trip to home depot, $30 for a piece of 1/8" thick aluminum 2 feet by 2 inches. I drilled a hole in one end, and got 2 big washers and a bolt and bolted it thru the stock rubber lower radiator mount on the passenger side. Then I line it up with the lower mount on the civic radiator, drilled another hole in it and slid the mounting peg on the civid radiator into it.Originally Posted by underated
4G64/63T
AEM EMS
UPDATE UPDATE UPDATE!!!!!Originally Posted by Cali
Ok so I just tried this today, the EVO radiator hoses WILL NOT WORK in our car with the EVO radiator. The hoses are 2" too short, this makes sense since on the EVO the radiator is close to the motor. I was the ginnea (sp?) pig for this one, dont make the same mistake. I just bought a set of $100 samco radiator hoses that dont fit. NO GOOD !
4G64/63T
AEM EMS
so the Galant hoses won't work on an EVO radiator??
LOL I dont know that either. I dont have stock 8g hoses anymore because I havent had a 4G64 motor in like 3 years. I'll try to get my hands on some. I think the galant lower hose will work but im skeptical about the upper hose.Originally Posted by Serstylz2
4G64/63T
AEM EMS
I though i would give this a try since my radiator started to leak. what modification did you use so it would fit into the bottom mounts? i noticed when i got the evo radiator the bottom mounting pegs are wider apart than the galant ones. i tried to modify the bushings but then i can't get the top pegs to line up good enough to use the top brackets on it to hold it in place. also did you put both fans back on or would just one work? any help would be great. thanks.
I cut off both bottom pegs, sanded them smooth, lined up the radiator to clear the headlights and fit the top brackets, then I marked the bottom of the radiator and I used plastic weld and DuraMix plastic adhesive to put the pegs back on. A body shop can do this if you dont feel confident. For the upper mounts, I used a dremel and I slotted the bolt holes in the bracket itself, I sorta made them oval from side to side, to allow for some adjustment to get it to fit nice. I have a slim line fan, I never tried it with a stock fan.
4G64/63T
AEM EMS
I got everything back in to where it fit and looks good. i went to the dealership to get some fluid to change in the auto trans and asked about the evo fans. they kinda looked at me funny when i told them i had an evo radiator in a galant. i'm just wondering about fans, should i get 2 and wire them in? they said i would need two cause of my a/c condenser. so would two slim line fans work to keep the radiator and condenser cool without some sort of a fan shroud covering the back side of the radiator? also told them i had an outlander manifold on there and they got a weird look on thier faces. told them the stock on broke and they said i should have put a brace under the throttle bodie lol.
You can get two 10" slim lines for about $50 each and wire them up to a relay and use the stock turn on wire to turn on the relay and it will work fine. Two slim lines will definetly work good enough without shrouding.
4G64/63T
AEM EMS
