Originally Posted by
laxinwarrior
Ok so I had the G on the jack today and I was poking around underneath looking for oil leaks to see if it was all being lost through the turbo and I noticed that my return line has a nasty ass kink in it that restricts it to about half the flow it is supposed to have. I don't know if this is because i am running a small 16G or not but there is a weirdly complex angle to the return line due to the outlet on the turbo being in a weird sport compared to the tap on the oil pan. :? Also the pushlock lines don't have very good flexibility which i'm sure didn't help the situation. Goddamn pushlock lines!! For those of you that don't know much about turbos, the return lines are gravity fed and that's why they are much larger in diameter than the feed lines. This usually allows it to drain off all the necessary oil but with half the return line blocked off like mine is, it more than likely is backing up to the point that the oil is being forced through the seals in the turbo. Anyway I am now waiting on a stainless braided line that which should take care of this problem.
Moral of the story: Don't be a complete fucking moron and jump to conclusions without checking for the easy solutions. :oops:
... I will still be upgrading turbos but after reviewing some more compressor maps, I have most likely decided to go with either a 50 trim ball bearing or a gt3076r.
