hey Joe, i'll run up to the JY this week and pull the CAS off a 2g Spyder and pull the distrib outta one of the 7gs, i'll take pics and everything
warning issued for off topic banter.
lets get back on topic.
laxin's turbo build.
ok I really didnt know I was gonna get a warning for this I apologize for this
and thank u guys for the answer and good luck on the dyno Laxin, can't wait to see ur numbers
p.s. warm I know that Ladin has a 7g not an 8g
'91 Kawasaki ZX7 (SOLD)
'95 Kawasaki ZX9R
are you still gonna dyno with the joe tune?
so you are trying to ditch the gen2 and run the eclipse ecu or run both?
keep us updated, if this works i may have a solution for my management on my turbo set up
it woudl be best to run gen2 and an eclipse ecu.
Ill be sticking with the gen2 as well but want the knock control and fuel and timing maps from the turbo ecu. I installed my wideband last weekend so I am actually able to tune it in now.
And I don't see why it won't work, the 2g spyder guys have been running the turbo ecu on the 4g64 for a few years now. The only difference between the two is the distributor on the galant. I just haven't seen anyone try it yet, that's all.
222whp/250wtq
if you need help we can make a mini meet
Mini meet could be fun ... But would you really want to drive all the way up here just to watch me cut and splice a bunch of wires? :p
222whp/250wtq
you know it's an excuse, last time i was there the turbo project was being a pain in the dick
Hey Laxinwarrior, How much did you put in to that turbo build? All parts?
I couldn't say, I haven't really kept a running total or anything but if I had to guess I would say around 3 grand. Not including any other mods either.
222whp/250wtq
I will be doing the ecu swap in the next couple days. I will be staying SOHC and using a 2.4 Spyder cas housing, cas, and cas pickup cylinder, and 2g coil packs and power transistor. After studying the schematics for the 2g eclipse and the 7g, here is what I came up with as far as wiring.
CAS wiring:
Pin 1: 12volts - Black/red at dist (5 pin plug)
Pin 2: Signal wire - Brown/green at dist (5pin plug)
Pin 3: Ground - Black wire at dist (5 pin plug)
Power Trans Wiring:
Pin 1 and 8: Coil Pack Outputs
Pin 2: Pin 23 (2g ECU)
Pin 3: Ground - Black wire at dist. (5 pin plug)
Pin 4: White Wire at distributor (2 pin plug) - tach signal (Pin 58-2g ECU this wire is moved from Pin 31 on 7g)
Pin 6: Black/white wire at distributor (2 pin plug) - 12volts - also goes to coil packs
Pin 7: White wire at distributor (5 pin plug)
Knock Sensor:
Signal: To Pin 78 (2g ecu)
ECU:
ECU power: Tap an ignition signal wire and run to pin 82
Knock LED: Run wire to pin 11 of ecu. (Optional, but I like to see knock. If doing this look up knockled on vfaq.com)
ISC:
Still haven't decided what I am going to do here since I am not swapping tb. I have a 2g isc, but not sure if it fits
Thanks a lot man, you just saved me a few hours of going over pinouts and diagrams. :) As far as the 2g isc, I don't know if it will work on the stock TB. I know the TPS is completely different though.
222whp/250wtq
Well, I attempted to do the swap this evening with no luck. The end of our cam isn't threaded, so the cas cylinder won't bolt up. Not only that, but the part of the cas cylinder that meshes with the cam is a little too large. I was very discouraged, but i will take another crack at it shortly. I am going to drill and tap the cam and grind down the cas cylinder so it will fit in the end of the cam. The only other options are to source a Spyder cam, or modify the cas plate in the dist to output 2 pulses. This would require welding on another tab to the plate. If the drilling, threading, and grinding doesn't go as planned, this will be my next option.
222whp/250wtq
Good deal! Now just cam that sumbitch to flatten that torque curve.
Very nice numbers on the dyno Laxin! How much boost were you running on those numbers?
10 psi
222whp/250wtq
Nice..what was your A/F ratios?
