Thread: Is .70TR a bit overkill?
Showing results 1 to 10 of 10
    8G_GTZ
    I found a used T4 .70TR for sale from a guy I know here at the Auto Zone by my house. If it needs rebuild, then thats cool, when thats done, it will still be cheaper than buying it brand new. I've got my forged internals coming along with the cam from Ripp.
    Just wondering if that was a bit overkill on the motor?
    Also, what would be the recommended inj size and fuel pump size?
    Finally, what management system/software should I go with?
    Much appreciated, Steve
    thats overkill..
    go ahead and ship it to me and i will take care of it.
    Is it a straight T4? What is it off of. Need more info. Injectors are different for a v6 then 4cyl, it all depends on what boost you are wanting to run.
    08-04-2003
    NY
    4,344
    I've never heard of a .70TR
    Get some pics of this thing.
    99' Galant ES
    4G64/63T
    AEM EMS
    .70 is going to be big. I dont even know if your v6 would be sufficent. What turbo is Jetblack using? I wonder what the lag time would be.
    Signature wanted call: 1800-Darkkend
    <a>Take Better Photoshots Tips from the Pro's</a>
    8G_GTZ
    I don't know anything other than that. I'll stop by the AZ tomorrow to see if he is working or not, and if he is, then I will see if if I can look at it.
    05-14-2003
    Southern California
    1,404
    DO NOT BUT IT!!!!
    Don't bother with a used turbo. If your already spending the money on building up your motor (which I commend you for), then don't skimp out on the MOST important part of this whole project....the turbocharger itself.
    Especially if you don't even know a single specification about it (e.g. .70TR actually means .70 AR....though we don't know which housing that refers to).
    Since your already upgrading the engine, then I strongly suggest some sort of BB. Considering the platform I would consider the GT3782R, or the GT3576R.
    BTW Do you already have a manifold setup, or do you plan to have one fabricated for you (pretty important)?
    8G_GTZ
    Quote Originally Posted by Jet Black
    DO NOT BUT IT!!!!
    I'll design it and then have it fabbed up. I have guys that also have CAD that can fix the things that I do in my designs.
    05-14-2003
    Southern California
    1,404
    Quote Originally Posted by 8G_GTZ
    DO NOT BUT IT!!!!
    Since you know some guys that work on CAD, see if they also have some experience with CFD. CAD is great and all, but when it comes to fluid flow, it is somewhat useless. The ideal approach [in this case] would be to design and test (via CFD simulation) manifold designs.
    Either way, try to avoid using the existing design for the exhaust manifold if you can. Granted it will work, but the overall flow characteristics are absolutely trash. At the very least try to mimic something like this:
    http://www.3si.org/forum/showthread....ght=big+baller
    8G_GTZ
    those designs look really good. I'm wondering if there will be enough room overall on the rear mani. to run it like that. I'll look today to see what kind of room I have to run this setup.
    Steve
