Thread: compression
Showing results 1 to 2 of 2
    compression
    I'm trying to find companies with piston/rod sets that will increase the compression of a 4G63 to 10:1. Other than Magnus Motorsports, does anyone have any suggestions?
    1990 Galant GSX: HKS Super flow, front strut bar, KYB coil overs, UR underdrive crank pulley, Greddy Kevlar Timing belt, Revolution muffler, custom grounds, Center Force clutch, Fidanza flywheel, Pace setter header, 4 wheel cross drilled rotors
    Call weisco or cp and order custom pistons.
