Thread: Amp problem
Showing results 1 to 4 of 4
    Amp problem
    My protect light is on on my zeus amp. How do i reset it and make my amp work again. (It's amped to my speakers) I want to get it off protect mode.
    New Member
    10-25-2006
    Westchester County, NY
    82
    unplug the speaker wires form the amp, make sure you have a good ground. if it still goes into protected mode then your amp is toast.
    if it powers up without issue then you could have blown speakers or a short somewhere in the line.
    2003 ES 2.4L - 150k - Stock
    tranny flush, timing belt, tensioner replacement at 80k
    check your wiring (battery, remote, ground,) check your fuses and speaker wires
