Headlight Bulb direction.
How do i change the angle/direction of the bulbs in the headlight. I just changed the bulbs and unscrewed the damn screw on the headlight, now i think the bulbs are not positioned right.
I have a 00es. The headlight up and down position is a little nut (10mm?) with a jagged toothed washer on it... sort of beside the bulb housing (side closest the radiator). I pointed the lights at the garage door and turned the nut to fix my headlight beam. I can't remember which way (CW & CCW) moves the beam you'll have to experiment....
Good Luck
