Member
Grill with JDM heads
Hey i think I already know the answer but will i need to def. change my grill to fit the JDM heads or can it fit with just the cutting by the radiator?
cutting the radiator???, that makes absolutely no sense at all reguarding the grill bro...there is a tutorial on how to install the jdm heads, for some reason i thaught u did already, but with the jdm heads you need a jdm grill its a smaller size then the usdm cutting into the frame is only required while actually installing the heads
Yep. You will need a JDM grille.
