Thread: Best Ground On 8g?
Showing results 1 to 20 of 24
    Best Ground On 8g?
    what's the best ground for my amp and speakers.... Right now i'm getting a noisy backfeed and when i accelerate it gets louder. I was thinking of grounding it to the battery (-). Is there a better ground and will that solve my problem?
    under the back seat and on one of the seat belt bolts
    FOUNDER OF THE EVO WING ON A G GROUP member #1
    04-13-2005
    Schaumburg, IL
    1,455
    Quote Originally Posted by mattalicslvr8g02
    yaa the backseat...i had that when I had my "system"
    you ground your speakers??
    you ground the amp and the main power wires
    you ground the amp, but i've never heard of anyone connecting speakers to ground.
    well subs have a positive and negative .. there is no ground.. . all he will have to do is ground the main wires going back and ground the amps
    i know that. im saying he might be having problems with his speakers because he's connecting them to ground!!!!
    Quote Originally Posted by thealliance43
    lol maybe he thinks they need to be grounded
    no i was talking about my amps.... i have 1 amp for my subs 1 for my speakers..... and you have to ground the amps.... which ground is best the seat belt? and are you talking about the seatbelt on the backseat when you say backseat? Thanks for the help guyz
    here is where the factory electrical components ground to
    but really, any good hunk of metal connected to the car's chassis is good. if that place is painted, scuff off the paint to get a good metal to metal connection. oh, and if you plan on drilling holes, make sure you don't drill into anything important.
    01-24-2005
    DFW/Stillwater
    2,752
    i used the bolt that holds on the 3rd brake light. no whining and has served me right for three years now. also there is very little paint on that area if any
    Ground should also be no more then six inches from the amp if you can do that and some people make the mistake of running the rca's down the same side of the car as the power wire. If you can run them down each side of the car...
    www.edelhausrottweilers.com
    Quote Originally Posted by Prophet
    RCA's are on the opp. side. 6" ground. Good suggestion i'm gunna try it tomorrow. Thanx again
    Well i dont have my galant anymore, i have a G20
    But if i remember correctly, there was a few bolts in the trunk and i just sanded the paint off so it would be a good ground.
    If you decide to drill holde make sure it is not under he back seat cushon the gas tank is uner there
    04-10-2005
    NYC
    3,695
    yea just go to one of the seatbelt bolts if you can, how many watts are you pushing what size wiring do you have? how did you run the wires are they all on the same side? these are also things to look out for
    grounded it to my seatbelt in the back today.... :( still same issue.... is it a fact that the ground has to be around 6" only b.c. mine is longer (4 gauge) then splits into 2 8guage wires....
    Keep it one solid wire, dont try spliting the wires because at the spliting point your causing a spot of week installation. And for a ground wire its recommended to keep it close to 1 foot or shorter. The best way to groung the wire is find a spot close to the amp where you can drill though the metal with out drilling to the out side of the car. Then sand any paint off that area and screw down the wire so its pressing down on bare metal. You can then spray some paint back over the area to help cover up any bare metal spots that might be expose. I had the same problem once i shortend up the wire and made a good ground it went away. Also make sure all your other wires are good. What i mean is make sure you have good installated wires.
    A bad ground is also just one problem with a buzzing sound. It can also be other things not related to a bad ground. A bad ground is just normally the problem and solution....
