Thread: Best Ground On 8g?
Page 2 of 2 FirstFirst 12
Showing results 21 to 24 of 24
    Quote Originally Posted by Prophet
    A bad ground is also just one problem with a buzzing sound. It can also be other things not related to a bad ground. A bad ground is just normally the problem and solution....
    examples? or what others have said
    12-27-2005
    Charleston SC
    1,520
    get some better rca cables
    New Member
    02-18-2006
    Lake George, NY
    91
    check the ground for your headunit. A lot of times the problem is with the source of the signal.
    Sold
    New ride...
    2002 Lincoln LS V8
    If you've moved your grounds around that much and still get static, you probably need better, or newer wires. As for me, I've grounded my amps on the side walls of the trunk, kind of near the existing stock ground. At one point I also had it under the back seat, not on the seat belt bolt, and that was fine too. Check the wires
