Thread: newest engine pic
Showing results 1 to 11 of 11
    newest engine pic
    -picking up 550cc injectors this weekend
    -maf translator gen2 coming in about two weeks
    "driving a honda is like being in the special olympics, even if u win ur still retarted"
    04-25-2007
    727
    Very Nice.... did you do the IC piping yourself, what size is it?
    i did the whole project myself, including the intercooler piping and exhaust. i did all the welding and custom fabrication. for the charge piping, i just bought a whole bunch of straight peices and some 90's, fit it all together and welded them in place. i was actually pretty straight forward. i welded the bov flange to the upper pipe and clamped it to the lower pipe so it can be taken off easily.
    ^^^nice work :smt038
    2001 5 speed 4g64T
    thanks! its 2.5" charge piping btw
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    Looks great..........nice work.
    05-25-2006
    New York City
    1,028
    Looks good but fyi the bov is welded on to close to the tb. When you get the gen 2 make sure to put it closer to the tb than the bov that way you don't have problems stalling between shifts when venting. Nice work though :smt023
    2000 Galant ES = Daily Driver
    ya, im putting the maf right on the throttle body, i kinda planned it that way. i already tried installing a gm maf for mock up and everything fit up perfect so should be no problems
    so are you driving that with no mas right now?
    yep lol well not really actually it runs fine surprisingly but idles high and has horrible gas mileage. i dont drive it on the road right now because its not done but i can start it up and drive it down my street and back. im not going to kae it out and drive it alot untill its all done and i know everything is running smooth.
    well i suppose the no MAF "limp home" mode that the ecu goes into isnt too bad for turbo, as it just gives it as much fuel as possible until the code is reset...
