Ohh my.. damn i have never heard of something like this..Okay ima going to try and help u as best as i can... You personally are not going to be able to tune ur car properly withot the datalogger, i ran into just about the same problem a year ago, my car was running lean a shit and i couldnt figure out why until i ran into a from mitsu and he told me. your best bet is to get the OBDII datalogger then try to tune it up, from there.. because trying to tune it yourself without it, will in most case cause more problems than solve anything..I remeber when i was getting my car tuned, they took about 2 1/2 to 3hrs to tune it right.. i say take it to a pro a let them fix it..I would assume that computer off the Spyder is the same for the 4g64...
okay you have Short term Fuel trim and Long Term Fuel Trim. (i.e. STFT & LTFT..) this is what i can come up with if ur LTFT is (+) Lack of fuel or too much air. the computer is attempting to increase the amount of fuel by increasing the injector open time. This could happen because of a leak pass ur Mass sensor or a clogg in the fuel pump.. now if ur
(-) could be 2 much fuel... the computer is tryin to lessen the fuel, by going back to the default computer settings, thats what mitsu has implimented into our ECU's.
if ur STFT is (+) your having low back pressure..check the pipping for leacks and cracks, i remember i had one and didnt even know it..
When ur tunning or try to tune it the only way ur going to run open loop on to ur ECU is when ur STFT is reading 0.0ms.. If u take it to get it tuned the guy their will set a LTFT DTC default so the ECU determines the fuel delivery except the oxygen sensor..
