Thread: heres something that a lot 7g deal with
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 69
    Member
    FT. Lauderdale, FL
    285
    on your galant did the dash peel away from the vents on the dash all the way in front of the winsheild peel up an shit, like it detaches from the plastic vent, how do i fix that?
    "One good thing about music, when it hits you, you feel no pain." - Bob Marley
    im not for sure how to fix it buy my passenger side airbag is kinda startin to come up a little in the corner and up by the passenger side windsheid defogger its startin to kinda peel up.
    Member
    FT. Lauderdale, FL
    285
    thats what i mean the defogger vent
    cantbeatmy97
    yea mines been like that for awhile i tried to buy another and that didnt work so im thinkin it the whole dashboard thats screwed up. i used sum 3m double sided tape and trimed around that piece.g/l to u
    Member
    FT. Lauderdale, FL
    285
    explain that, u got pics?
    dukeplaya3169
    I'm not positive as to what you guys are talking about...but if I'm right in my thinking then I would suggest to try heating up the peices that are peeling off, get some adhesive like superglue (so it's clear and not noticable if you screw up) and bend/glue the peeling peices back in place.
    95G-Hustler
    i dunno bout urs, but my defogger vents have these things that hold it down
    Mine on both sides are coming up. I was just thinking about that the other day. Does anyone know if these vent are sold?
    YES I STILL HAVE MY GALANT!!
    Dark Anghell
    WTF :evil: the same thing is on mine...and it's only right side. Maybe we should contact mitsubishi, and hopefully they will do a recall or something . I'ts worth a try.
    Member
    FT. Lauderdale, FL
    285
    do it, i gotta start living up to my name (ViciousLord) i been to nice, il be more then happy to bitch at them.
    oh and by the way fuk everybody on this board!!! :firedevil: j/k
    Hell yeah contact em bout replacing all of them if there so many people with the same problem they better do a recall and replace em for free!!
    Kain
    Uhh, recall ain't never gonna happen. That happens to every vehicle in time. It's due to the material that the dash is made out of. It's like a foam stuff covered in the vinyl material that you see. The sun causes the foam to expand and the vinyl to shrink, or something like that. But, on the part of the dashboard that is most exposed to the sun it happens the worst. Also, the airbag on the passenger side is noticable because it's a small segment within a much larger segment.
    My airbag cover is doing it to.
    I'm sure we can get 40 people from here. I'm sure there's plenty more.
    If we get 100 people, maybe they'll fix it.
    TurboGalant
    I've seen double posts, but I think that was the first triple post I've seen.
    I have a dash mat to protect my dash board. Maybe you can get one and cover up the damage, if all else fails.
    Good luck.
    Member
    FT. Lauderdale, FL
    285
    ok where do i go to get one, link?
    give me something
    <div class='quotetop'>QUOTE(TurboGalant)</div><div class='quotemain'>I've seen double posts, but I think that was the first triple post I've seen. Â*
    I have a dash mat to protect my dash board. Â*Maybe you can get one and cover up the damage, if all else fails.
    Good luck.</div>
    lol give him a break...hes on AOL
    Here's where you find one
    All,
    I have seen these in several
    different catalogs, unfortunately
    I cant remember exactly which one
    it was Go to www.jcwhitney.com
    I think they have them or they can
    order them at AutoZone www.autozone.com
    or Advanced Auto Parts www.advancedautoparts.com
    Try JC Whitney first. My 97 ES doesnt have
    that problem (just knocked on wood)
    but if it happened to my car I would
    just get a cover for it.
    paulbunyan
    blah blah blah
    sleepagalant
    i have the same problem with my airbag and my defogger vent
