Thread: Camshaft Timing
Showing results 1 to 3 of 3
    richie
    Camshaft Timing
    Can anyone tell me how to line the timing marks up on the 2 camshaft sprockets on my 1988 2.0i twin cam 16 valve galant?
    bongi
    there is usually a timing mark in the both sprockets and also the timing belt cover as well as a mark on the crankshaft pulley and the engine. usually, just align all three of them and connect the timing belt. I am not definite with your 2.0 L engine as I have the 3.0L engine. chack pepboys and look at the chilton manual for mitsu's or try your local library.
    richie
    thanks 4 the help.
    <div class='quotetop'>QUOTE(bongi)</div><div class='quotemain'>there is usually a timing mark in the both sprockets and also the timing belt cover as well as a mark on the crankshaft pulley and the engine. usually, just align all three of them and connect the timing belt. Â*I am not definite with your 2.0 L engine as I have the 3.0L engine. chack pepboys and look at the chilton manual for mitsu's or try your local library.</div>
