SUCH A NOOB...J/K.... ill research a lil for you
I just picked up a 93 Diamante and they is no aftermarket support for the cars at all. Anyone know if the 8G springs are the same? I want to take a wild guess and say the 91-93 3KGT SL are the same.
93 3000GT
93 Diamante
you might want to look into AU since the diamante is bigger there than it is here. then there's always caps if you want matching part numbers.
from the pictures you posted it doesn't look the same.
Did a parts lookup and it checks out. 3kGT works.
front
40176 for the spring
40041 for the strut
rear
41197 spring
41422 shock
i just went and looked at the old stock stuff i pulled out of my car
i'd have to say, if it's not the same, it's at least VERY similar
are there any good diamante forums to help you out?
> TGCPA - SOUTHEAST
> 1999 ES V6 (Sold 2/2011)
Theres a site diamanteowners.com but not very active so I'll be doing everything myself mainly.Originally Posted by glantv699
yeah i'm a member of diamnte owners.com
the 3kgt sl setups will cross over
get a 3kgt non turbo intake. it will be a perfect bolt on.
the suspension is the same as well as the brakes.
many similarities
