Thread: Rattling/dribbling/drizzling, w/e under the car.
Showing results 1 to 15 of 15
    10-18-2003
    722
    I just started nothing this recently... if i slap it into 1st gear, accelerate until about 4k and let go, between 3 and 4k with the exhaust sound i hear the drizzling noise like metal hitting metal at very high rate. only for like 1-2 seconds though. It seems to be coming right under the gearbox...
    Now if i move the exhaust forward and back, it moves rather free, because of the rubber hangers obviously.. The only problem i can think of would be when i tried to pull the car out of the ditch and hooked to the wrong thing, and heres the result:
    As you can see the exhaust pipe is very close to that metal sheet now.
    I am going to try to fix that tomorrow, that is to get it out form the way as much as possible, but as i said, the sound is coming closer to the engine bay, just after teh cat. It's liek of like a bzzzzzzzz sound only metalic.......
    thoughts?
    When I got my Megan catback installed it rubbed against that metal sheet (safety guard?) pictured above, so they shaved some off. Weeks later, it would make a squeaking noise on and off. I thought it might be the suspension. But as it turns out it was the exhaust rubbing up against it again, so they took more off. Problem solved.
    10-18-2003
    722
    would it make that noise when u let off teh gas and it would rattle, obviously? or just out of random?
    flex pipe leaking? i know mine is
    mitsumitsu aka luke9511
    Quote Originally Posted by lKoRTy
    Bumps and grooves in the road would make it rattle and give off a clunk clunk sound. Which means it was just bumping up and down and hitting that metal part, so it was a constant sound. But sometimes the exhaust pipe would get stuck in a way that it would rub along the metal part and make a squeaking noise. The squeaking was more noticeable when letting off the gas, but even at a red lights and whatnot you could hear it squeaking.
    I'd just get that taken care of first.
    10-18-2003
    722
    hmm ok i will try to do something about the metal part.
    and luke, it does sound like it's coming form the flex pipe. could you hear yours constantly? or?
    i hear mine all the time i can take a sound clip once i get home to see if it sounds like yours or not
    sound anything like this? http://luke9511.freepgs.com/sound.wav
    10-18-2003
    722
    nope, mine only does that when i let off the gas at high rpm's...
    Btw r u coming to the import alliance?
    i forgot about that and i dont know as i dont know my way around downtown and have you told redgalant1 about it?
    10-18-2003
    722
    no, i havent. it's going to be at the stadium (Titan's i believe). Im sure u can find it.
    im like 5 minutes from downtown, and i have never been there by myself before so, but i will get a map and see how that goes
    10-18-2003
    722
    you should dammit. plus we gotta find more galants there and recruit ppl for tgc lol.
    theres a couple of galants at my school that i need to put flyers on, also how much does it cost to get in?
    10-18-2003
    722
    i believe its free.. its a public stadium parking lot after all....
