Thread: Kalamidad's Outlander Intake Mani quest.
Showing results 21 to 40 of 45
    11-24-2002
    Originally TGCNY, Now TGCTX
    1,781
    hmm. ok. In that case, i'll just order it when i go pick up the gasket seals. Thank you for the heads up.
    -Pedro
    09-10-2003
    Charlotte, NC
    4,463
    very true, mistubishiparts is cheap but slooow
    08-23-2004
    Chaska, Minnesota
    1,370
    use the galants t/b cable just take out the slack, jimmy rigg it
    11-24-2002
    1,781
    Quote Originally Posted by krispy03
    i ordered it today from the dealership. Should be in for a couple of days. I may have to drive around with the Galant throttle cable for a weekend.
    -Pedro
    11-24-2002
    1,781
    the mani is out. I'm posting pictures. I tried to take pictures of every possible angle i could think of for the 03 outlander mani so other guys can know exactly what it looks like. i'd left the gasket seal at my sister's house so when she gets here, i'm putting the new one in.
    -Pedro
    08-08-2004
    Las Vegas
    2,099
    just use the galant throttle cable...
    what you need to do is look at the gas peddle and find the 2 bolts that secure it to the car... unbolt those and put some washers between the body of the car and the peddle... problem solved
    thats how i have mine setup and the good thing is the peddle feels the same as stock
    TGC Lifetime Patron XsinshineX's Avatar
    11-11-2006
    Pigeon Forge, TN
    143
    i used the outlander throttle cable. it's shorter but different where the mounting on the firewall from the galant. Mine bolted to the firewall with two bolts holding it to the firewall. the outlander doesn't have that set up it is made with clips so that it is pluged into a hole and the clips hold it in place from the other side. i had to get a file and enlarge the hole at the top and bottom into a more square shape. not much though. when i got it locked in i put the bolts from the other cable back in on each side of it to add a little extra stay in place security in case it wanted to pop back out. i didn't get any picts but if its not raining tommorrow i'll pop the hood and take a few.
    11-24-2002
    1,781
    ok, so the TPS came attached to the mani but it didn't bring the black box where the wires come out of. so i have a TPS and no way to connect it to the wiring harness.
    suggestions?
    Also, what did you guys do with the ground sensor that was on the many? did you cut it off and connected it to something else? i'm talking about this one..
    where did you connect it?
    in theory, if i can just splice those wires together and connect them to the mani somewhere, i can use the connector peice on the TPS. But i don't think i can just splice those together. can i?
    -Pedro
    07-23-2004
    San Diego, CA
    1,496
    Quote Originally Posted by lonestar22
    its obvious you guys need different intakes or something
    what intakes are krispy and kalamidad running?? just wondering...
    11-24-2002
    1,781
    Quote Originally Posted by o1naturalhigh
    i'm running an injen RD intake.
    -Pedro
    08-23-2004
    Chaska, Minnesota
    1,370
    mine broke on stock intake, THE BOX!
    your going to have to order a new TPS mine came broke too :?
    you can drive your galant without the TPSbut dont expect a good response. also i wouldn't suggest accost town.
    11-24-2002
    1,781
    yeah, i'm gonna have to pick one up. i'm gonna use electric connectors to connect to the pins to see how that works. i got the order of the wires from Underated's tutorial. i'm not going far without the real tps.
    -Pedro
    08-08-2004
    Las Vegas
    2,099
    that ground sensor i just bolted to the valve cover... im not sure if it works the same but you may be right about cutting it and maybe put a ring terminal on the wires then connect it to the firewall be cause the manifold already has a ground point.
    anybody know what happened to manybrews? the mitsu tech
    08-08-2004
    Las Vegas
    2,099
    looking at the pic again i didnt have that other sensor to the right... whats that for?
    11-11-2006
    Pigeon Forge, TN
    143
    here's what i did with mine. its the one right above the throttle cable bracket.
    08-23-2004
    Chaska, Minnesota
    1,370
    Quote Originally Posted by XsinshineX
    see i dont know what that sensor is for, i dont have it. mines an 03.
    08-08-2004
    Las Vegas
    2,099
    i dont know what its for either i havent seen it in the service manual either.... i left mine hanging for awhile to see if it affected anything and it never did...
    anybody close friends with a mitsubishi tech?
    11-24-2002
    1,781
    well, its january 08 now. do i still have to tell you guys that the swap was a success? LMAO!! sorry. lol
    thanks for all the help though. You guys are great.
    -Pedro
  19. #39
    08-08-2004
    Las Vegas
    2,099
    what did you end up doing with that sensor? i figured out what its for and how to get rid of it lol
  20. #40
    11-24-2002
    1,781
    i grounded it to the egr sensors bracket which happened to be metal. no problem six months and counting.
    you where really helpful. thanks again brandon.
    -Pedro
