have you tried starting the car? If so what does it do?
got a DTC 17..would this keep my car from starting?
paid4.....99 galant
the car does nothing..but all power is on...no dim lights or anything..eng wont even turn....
paid4.....99 galant
Has the starter ever been replaced?
nope..Originally Posted by RedGalant2k1
paid4.....99 galant
Have you tried tapping the starter?Originally Posted by paid4
If you don't know what that means, it literally means tapping on the starter with a hammer (or some kind of tool) and having someone crank the car at the same time.
As another question have you tried jumping the car?
tried tapping...and jumping..nothing.....only thing is a buzz or clicking noise near the throttle body...and that stops after a few seconds
paid4.....99 galant
If you have tapped it, jumped it and nothing sounds like the vehicle needs a starter. If you can get the starter out any of your local auto parts stores should be able to test it. And while your at it get the battery and alternator tested.
what about the DTC 17 code?Originally Posted by TederickR
paid4.....99 galant
Could be the fuel pump.Originally Posted by paid4
Have you tested to see if you can hear the pump turning on?
well i know its not getting gas.....i wonder if ther is a way to reset the imobolizer..?
paid4.....99 galant
Did you or someone try to start it with a improperly programmed key?Originally Posted by paid4
If so you'll need to take it to the dealer so they can properly code a key for the car.
If its not getting fuel then either the fuel pump, or sending unit is bad. Which means your going to need a new fuel pump/sending unit assembly. Which actually is an easy job on our cars.
if so about how how much...no one tried to start the car with a improper keyOriginally Posted by RedGalant2k1
paid4.....99 galant
fuel pump could be shot....
well i dropped it off at the dealer...lets see how they rape me! i will let you guys know....
paid4.....99 galant
gillman off 45 north....i am just tired of fucking with it.....i even tried to hot wire it..and the eng. cranked..but would not start....Originally Posted by TederickR
paid4.....99 galant
