call the dealer with your VIN, they could tell you if it's got it or not...that's how I found out...
I just found out while buying parts for the 8g that it came with keyless entry from the factory. We never got the key fobs when we bought the car and the previous owner was a theiving idiot, he didn't inform us.
Where is the keyless entry reciever module located in the 8g's? I want to make sure its there before I buy a couple of key fobs.
Thanks
8)
It's built into the etacs ecu. which is built into the back of the fuse box. If you look at the back of the fuse box, it has a sticker that will tell you what features the etacs is loaded with. BTW as long as you don't have a DE then keyless is standard.
Thank you gentlemen! I had my friend at Mitsu run the VIN and the car did come with keyless. I just wanted to make sure if the reciever module was still there...because the previous owner did not tell us some stuff about the 8g before me and my g/f bought the car.
is anyone else having a hard time getting their horn to chirp? i am with my keyless
Try this:Originally Posted by cdipier2
-Press and hold the lock button on the remote for about 7 seconds (atleast between 5-10 seconds)
-While pressing the lock button, press the unlock button
-Release both buttons
~Lady Driven~
Divinity,
Are those the steps to relearn or program the remotes?
thats the process to get the horn to chirp when u press the lock button.
but kevin, you said u had a friend at mitsu? get him to run the vin again and get the FCC Id's for the key fobs to make sure you get the proper ones.
also if you dont have a keyhole on your trunk you have factory keyless. just dont pay the dealer to "program" the remote for you. it is way easy and takes less than a minute.Originally Posted by 4-G-rim
yeah, i just bought two last week and got them both programmed in less than 2 minutes. Thanks to the tutorial 8) Can't believe how much they charge for that for as simple as it is...Originally Posted by anticon
To get the lights to flash I believe it's the opposite. Press and hold the unlock button for 5-10 seconds, while pressing the unlock button, press and hold the lock button, then release both buttons at the same time.Originally Posted by TederickR
Press and hold the unlock = flash lights
Press and hold the lock = horn chirp
At least it worked for me.
~Lady Driven~
Wheres the tutorial for programming the fobs.Originally Posted by 00GalantMan
~Lady Driven~
ive tried and tried and no luck. maybe something is wrong with it. did u do it with the door open or closed?Originally Posted by Divinity
Alright..got the the keyless to work.
Just wondering while programming the key fobs...if the car has the "Panic" feature will the panic buttons automatically get programmed?
I tried that programming the horn to go off when you hit the keyless Divinity and it didnt work for me.
^^well atleast im not the only one. i think there might be something wrong with my chirp feature thats why i cant get it to work
