Thread: Stunr: New engine management installed!! w/ vids
Showing results 21 to 40 of 46
    08-08-2004
    Las Vegas
    2,099
    damn nice work i wish i could do that with my 8g it would make my ITB setup less of a hassle...
    Whats next for the car?
    here are some pics of the install,
    Intake air temp sensor (IAT) bung tig welded in:
    sanded, primed and painted pipe, installed sensor:
    Manifold Absolute Pressure sensor mounted (MAP):
    time to yank the ecu:
    My ecu wiring is super clean, everything i've added since had become a little bit of a tangle:
    pandora's box:
    lets open it up:
    old EPROM removed:
    installing emulator cable:
    easy enough:
    done, ready to reinstall ecu:
    damn it just looks sexy sometimes:
    time to fab up the adaptor harness:
    start with some new pigtails:
    part i stole out of a old damaged MAS i had laying around, will be the male end of my SD harness:
    solder a few connections:
    time to seal it up very thoroughly:
    strengthening and taking the slack out of the harness with zip ties:
    then tape, then loom, then tape,
    finished product:
    picked up a new filter and a short piece of pipe to make a new "no recirculation bung" intake for the turbo. i forgot to take pics of it.
    will put them up tomorrow
    04-25-2007
    727
    Wow that looks really nice Stuner.... The video also sounds like your running really smooth. Well goodluck with the setup and hope to hear more improvemets and good results from that setup.
    how much hp do u think u have now?
    From 7g to this...
    Shot with DSC-T33 at 2007-07-21
    13.1@109 02 WS6
    Quote Originally Posted by Reptile
    right now i'd be suprised if i'm making 200 hp.
    but thats simpl cause my tune is completely off and i haven't had a chance to touch it.
    once i get it tuned, i'll be looking to make 400hp on pump gas daily driven
    07-20-2003
    Orlando, FL
    3,169
    Bravo man...Bravoo!!! :smt038
    Keep doing what you are doing ....very impressive.
    09-10-2003
    Charlotte, NC
    4,463
    Using seth's Youtube account i see... lazy ass
    damn very much so interesting and very impressive and I dont know what else what to say you did a very very very good job.....I love it..
    8g tranny is being rebuilt and waiting on ground control coilovers
    7g is just sitting motor and tranny is out(need to finish, just lazy)
    6g (vr4) motor is out getting the good stuff like a gt4088 and some more stupid stuff.
    Nice to be back!!!!
    Nice Install! But am i to understand this correctly that you are letting windows run your car now?
    The Ostrich EPROM Emulator runs the car, he only uses windows to update the Ostrich. So he can make some changes, update the Ostrich, unplug the computer and never have to worry about it again. Or he can leave the laptop plugged in and make changes on the fly while he is driving. Its very slick!
    New Member
    03-26-2007
    Pineville, Louisiana
    81
    Are you god? lol thats insane man, and so clean, the casual observer would have no idea... Awesome...
    Diamond Star Motors - Turning ordinary people into mechanics since 1989.
    02-28-2005
    Metropolis
    3,540
    Big things being done. Good job man.
    does this lose its tune with weather/elevation changes?
    not at all,
    the tune is based on the signal from a manifold absolute pressure sensor, and an intake air temp sensor.
    the effected variable with elevation changes is pressure.
    so weather i'm in new orleans or lake tahoe, the sensor will read whatever pressure is in my manifold.
    now, of course since the pressure will be less at higher altidtudes, it jsut means that the ecu will be using a different area of the table for its fuel calculations.
    of course the amount of power being made will still vary, but since we're turbocharged, it mainly means the turbo will work harder(spin faster) to make the same boost levels, but once those levels are reached of course the same power will be made.
    it doesn't matter if i'm at sea level or on a mountain, once i'm getting 20 psi @ x rpms, and 95* intake air temp. i'll make the same amount of power.
    if i was N/A the power level would vary of course cause all you have it the current atmoshperic pressure to work with.
    but the tune would't change. unless i tuned for a different a/f ratio and timing advance at different pressures... but of course thats what the factory ecu does with a MAS
    Quote Originally Posted by DOHCstunr
    Stunr, what engine are you running?a 4g63 or a 4g64?
    My friend has a stock 4g63 got 435 hp easily on 18psi of boost with a gt35 but he uses the microtech,(daily driver car) I hope the get around 400hp with my 4g64
    john has a 4G63 vr-4 engine with the cyclone itake mani i believe and a 50 trim turbo
    Quote Originally Posted by microgalant
    here is my mods list
    https://www.thegalantcenter.org/gara...vehicle&CID=57
    i'm sure i could get more than 400hp out of my engine w/o any problems, but as long as i'm on the street, i'd like to keep it around there. Don't want too aggressive of a tune in kentucky, the weather is always chaningig around here temps range from 0 degrees to 100.
    i just want a year round semi aggressive tune.
    i don't want to have to pull timing every summer since the air is hot and thin and vice versa, but i suppose i coudl always just keep a summer and a fall *bin ready for the seasonal changes.
    Member da1085's Avatar
    01-03-2006
    202
    DOHCstunr, i just got my ostrich. where can i iget a bin maker for my set up.can you send me a link where i can have a custom bin file for my set up.
    90 gsx eclipse:
    91 eprom ecu(done the wire swapping and running a 91 ignitor for the working tach)
    i have 510 inj
    16g turbo
    stock fuel pump
    fmic
    ##########sped density(will have it once the sensors gets to my house)
    2g maf in a 1g
    i would like these options on the code also:
    stutter box (5000-5300 rpm because is still have the 3 bolt :( )
    venting because of the speed density
    octane reset
    revlimit at 7000 rpm(dont want to have it change i know the original is 7500 but i dont plan on getting higher than 7000)
    stock idle(750-800 rpm)
    i guess you can send me 2 set ups, one for speed density and one for the 2g mass or even the 1g mass set up. i would like to learn on how to do this but i need a made bin so that my car will run.
    i looked around and i only found the online maker but it doesn't have anything that would adjust my injector size, studder box, and speed density set up.
    im not good with hex. i have ds-map software, moates software and tuner pro but im not familiar with them. can you help me out?
  19. #39
    Stunr:New engine management installed.
    Three Questions
    Did you get that lean burn feature working?
    How is the learn burn code activated when you are on the road?
    Can this be installed before the turbo install? i kind wanted to do this installed and the manual swap at the same to to reduce the amount of times i have to break down the interior and dash.
  20. #40
    Noice! You will sure have a ton of fun with flash ROM.
    They have "moduals" (programs) for about anything you desire your engine to do. I'm sure even anti-lag, if you so desire...
    Very sweet work on the whole set-up if I did not mention it already. It's like Club3G pics!
