Thread: 2002 Galant rear 6x9 speaker dimensions
Showing results 1 to 8 of 8
    Would anyone have the following information available for rear OEM 6x9 speakers( 2002 Galant);
    Speaker Size: 6" x 9"
    Design: 2-way?
    Tweeter Design: Dome?
    Sensitivity: 90 dB?
    Frequency Response: 30 - 20,000 Hz?
    RMS Power Handling: 60 watts?
    Peak Power Handling: 120 watts?
    Impedance: 4 ohms?
    Top Mount Depth: 3" ?
    Any information would be greatly appreciated. I'm thinking of installing a set of PRC92 6x9 speakers and wanted to know if fitment would be "plug & Play". Thanks in advance for your help.
    Re: 2002 Galant rear 6x9 speaker dimensions
    Quote Originally Posted by GSpeed
    Design: 2-way?
    Sensitivity: 90 dB?
    Impedance: 4 ohms?
    Any information wold be greatly appreciated. I'm thinking of installing a set of PRC92 6x9 speakers and wanted to know if fitment would be "plug & Play". Thanks in advance for your help.
    The only specs you need to be aware of for fitment is speaker size and mounting depth everything else really doesn't matter.
    But the mounting depth is 3"
    RedGalant2k1, thank you. The Memphis speakers are 3in depth so shouldn't be a problem. The other specs are:
    RMS/Peak (W): 60/120
    Sensitivity (db): 90
    Magnet Size: 14
    Thanks again.
    NEWBIE
    01-02-2009
    Portmore, Jamaica..YUP!! YARDIE!
    9
    Speakers
    what are the size of the speakers in the front door of a 2000 galand ans whats the fitment depth?
    07-12-2007
    SoCal
    4,632
    Size of front speakers are 6 3/4" but you can also fit a 6 1/2" with out alot of modification.
    JDM Zenki Conversion
    I just put in new 6 1/2's last friday no modifications courtesy of crutchfield
    07-12-2007
    SoCal
    4,632
    Yeah it depends on the speaker mount with the speaker, my 6 1/2"s Infinity References didnt need modification either bcz the mount was made to fit 6 1/2" hole and 6 3/4" hole.
    07-12-2007
    SoCal
    4,632
