Thread: Pit BCU + Boost Control
Showing results 1 to 3 of 3
    Ok so was looking around and i saw this....
    http://www.performance-trends.com/boost_controllers.htm
    It's suppose to be a boost controller, turbo timer and everything in one box....Has anyone heard of them or seen this? I read about it over at a SRT forum and where i found the link to...
    I havent, but they look pretty darn ugly. You really dont need an electrical boost controller. Only reason you would even want one would be to lower the boost in first or second, then up the boost in your traction gear. You can do this with duel manual boost controllers though, a lot cheaper too.
    I don't know anything about there boost controller but there wastegates suck. I prchesed a 40mm and the diafram burnt out after a month. I would look into a halman. They are cheap and work great.
