Thread: found maintenance schedule...
Showing results 1 to 2 of 2
    07-23-2004
    San Diego, CA
    1,496
    ...on my local mitsu dealer site...doesn't go up to 120k though...
    *also, didn't know where to put this...so it can be moved to proper place if needed
    3,750 Mile Service
    • CHANGE ENGINE OIL
    • CHANGE ENGINE OIL FILTER
    • INSPECT FRONT DISC. BRAKE PADS FOR WEAR <REPORT CONDITION>
    • INSPECT AIR FILTER & CLEAN AIR FILTER HOUSING
    • SERVICE P.C.V.
    • INSPECT FUEL LINE & HOSES
    • INSPECT COOLING SYTEM FOR LEAKAGE
    • LUBICATE BALL JOINTS,TIE ROD ENDS <IF APPLICABLE>
    • LUBICATE ALL LOCKS,LATCHES & HINGES
    • TOP OFF ALL FLUID LEVELS <WINDSHIELD WASHER,BATTERY ECT.>
    7,500 Minor Service
    • CHANGE ENGINE OIL
    • ROTATE ALL FOUR TIRE <FRONT TO BACK>
    • COMPUTOR BALANCE ALL FOUR TIRES
    • SET TIRE PRESURE TO SPEC.
    • INSPECT REAR BRAKES FOR WEAR <REPORT CONDITION>
    • INSPECT WHEEL CYL & BRAKE CALIPERS FOR LEAKAGE
    • SERVICE REAR BRAKES AND ADJUST PARKING BRAKE <IF APPLICABLE>
    • INSPECT DRIVE BELTS <REPORT CONDITION>
    • SERVICE P.C.V.
    11,250 Mile Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    15,000 Mid Service
    • CHANGE ENGINE OIL
    • REPLACE AIR FILTER & CLEAN AIR FILTER HOUSING
    • SERVICE P.C.V.
    • ADD B.G. MI 3,000 GASOLINE SUPPLEMENT
    • ECT.> WASHER.BATTERY
    NOTE DELUXE SERVICE INCLUDES
    • CHANGE SPARK PLUGS <EXCEPT ON VEHICLE EQUIPPED WITH PLATINUM SPARK PLUG>
    • PERFORM ENGINE COMP. TEST
    • CLEAN AND ADJUST THROUTLE BODY
    • PERFORM SCOPE AND SET TO ENGINE
    • INSPECT SPARK PLUG WIRES
    • INSPECT DIST. CAP AND ROTOR <IF APPICABLE>
    18,750 Mile Service
    • CHANGE ENGINE OIL
    • SERVICE FUEL INJECTION SYSTEM
    22,500 Minor Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    26,250 Mile Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    30,000 Major Service
    • CHANGE ENGINE OIL
    • CHANGE SPARK PLUG <EXCEPT ON VEHICLE EQUIPPED WITH PLATINUM SPARK PLUG>
    • CLEAN AND ADJUST THROUTLE, BODY
    • INSPECT DIST. CAP & ROTOR <IF APPLICABLE>
    • SERVICE P.C.V.
    • REPLACE ENGINE COOLANT
    • REPLACE AUTO TRANS FLUID OR MANUAL TRANS FLUID
    • INSPECT TRANSFER CASE & DIFFERENTIAL FLUID CONDITION <IF APPLICABLE>
    • TOP OFF ALL FLUID LEVELS WASHER,BATTERY ECT.>
    33,750 Mile Service
    • CHANGE ENGINE OIL
    37,500 Minor Service
    • CHANGE ENGINE OIL
    • INSPECT AIR FILTER & CLEAN AIR FILTER HOUSING • SERVICE P.C.V.
    41,250 Mile Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    45,000 Mid Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V. ADD B.G. MI 3,000 GASOLINE SUPPLEMENT
    • TOP OFF ALL FLUID LEVELS <WINDSHIELD ECT.> WASHER,BATTERY
    • NOTE DELUXE SERVICE INCLUDES.
    48,750 Mile Service
    • CHANGE ENGINE OIL
    • LUBRICATE BALL JOINTS,TIE ROD ENDS <IF APPLICABLE>
    52,000 Minor Service
    • CHANGE ENGINE OIL
    • REPLACE FUEL FILTER
    • SERVICE P.C.V.
    • INSPECT FUEL LINE & HOSES INSPECT COOLING SYTEM FOR LEAKAGE
    56,250 Mile Service
    • CHANGE ENGINE OIL
    • INSPECT FRONT DISC. BRAKE PADS FOR WEAR <REPORT CONIDITION>
    • SERVICE P.C.V. INSPECT FUEL LINE & HOSES
    • LUBICATE ALL LOCKSLATCHES & HINGES
    60,000 Major Service
    • CHANGE ENGINE OIL
    • COMPUTOR BALANCE ALL FOUR TIRES SET TIRE PRESURE TO SPEC.
    • INSPECT DRIVE BELTS <REPORT CONDITION> CHANGE SPARK PLUG
    • PERFORM SCOPE AND SET TO ENGINE INSPECT SPARK PLUG WIRES
    • SERVICE P.C.V.
    • NOTE T-BELT IS RECOMMENDED AT 60
    63,750 Mile Service
    • CHANGE ENGINE OIL
    • LUBRICATE ALL LOCKS,LATCHES & HINGES
    67,250 Minor Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    71,250 Mile Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    75,000 Mid Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    • ECT.> WASliER,BATTERY
    78,750 Mile Service
    • CHANGE ENGINE OIL
    • INSPECT COOLING SYTEM FOR LEAKAGE LUBICATE BALL JOINTS,TIE ROD ENDS <IF APPLICABLE>
    • LUBRCATE ALL LOCKS,LATCHES & HINGES
    82,500 Minor Service
    • CHANGE ENGINE OIL
    • SERVICE P.C.V.
    86,250 Mile Service
    • CHANGE ENGINE OIL
    • INSPECT FRONT DISC., BRAKE PADS FOR WEAR <REPORT CONDITION>
    • SERVICE P.C.V.
    • LUBICATE, BALL JOINTS,TIE ROD ENDS <IF APPLICABLE>
    90,000 Major Service
    • CHANGE ENGINE OIL
    • CLEAN AND ADJUST THROUTLE BODY PERFORM SCOPE AND SET TO ENGINE
    • SERVICE P.C.V.
    93,750 Mile Service
    • CHANGE ENGINE OIL
    97,500 Minor Service
    • CHANGE ENGINE OIL
    • SERVICE REAR BRAKES ANI) ADJUST PARKING BRAKE <IF APPLICABLE>
    101,250 Mile Service
    • CHANGE ENGINE OIL
    • INSPECT FUEL LINES & HOSES
    105,000 Mid Service
    • CHANGE ENGINE OIL
    • INSPECT SPARK PLUG WIRES INSPECT DIST. CAP AND ROTOR <IF APPICABLE>
    07-19-2007
    Connecticut
    3,994
    wow thanks, ill go to my closest dealer and have them do the 90 and up since i doubt it was done when i bought my car from the dealership (it wasnt a mits dealer)
