I think the ground controls or most dampers will give you a 0-3" or 4" drop. For actual springs, would probably be the Eibach Sport Lines which are a 2.2" drop?
i know that the rear is the same as the eclipse and 8g but is the front the same as the 2g?
my other question is, what is the lowest i can get a 7g in the front on coil springs
alrigh tthanks.
what about the 2g suspension
you can take the 2g rear sway bar set up and hook it up to the 7g
