Thread: Need help to find performance headers
Showing results 1 to 20 of 34
    Member
    08-08-2007
    Minneapolis, MN 55407
    151
    Can't find any headers that will fit my car. Don't know where I can find some performance headers that will fit.
    07-20-2003
    Orlando, FL
    3,169
    RPW makes a 4-1 race header...my old 95 Galant was the first in the U.S to have them. A bit pricey..but not even sure if its still available. I believe OBX or similar company may make them. You can also try to find a application for a 97-99 Eclipse Spyder..they came with SOHC 4G64's like the 7g's.
    yes RPW does make the headers for us..but shippin from australia is abit pricey...to be exact you will need the headers for a spyder *GS* they will bolt up just right and remeber to change ur gaskets as well
    07-20-2003
    Orlando, FL
    3,169
    This is what the RPW race headers look like. The fit well..with the exception on where the runners make the 90 degree bend..it dips a bit lower than OEM. So if you are pretty low..you risk on scraping the header.
    Member
    08-08-2007
    151
    [quote="4-G-rim"]This is what the RPW race headers look like. The fit well..with the exception on where the runners make the 90 degree bend..it dips a bit lower than OEM. So if you are pretty low..you risk on scraping the header.
    What Kind Of Intake do you have like what brand? Just Curious casue everyone has their own way of installing an intake.
    Member
    08-08-2007
    151
    So Here are the Headers that I found on RPW probably will get them later on when I get some more money but for now Imma just keep websites on what I find.
    http://www.rpw.com.au/shop/index.php...mart&Itemid=31
    04-13-2005
    Chicago
    1,945
    i have the RPW headers on my car. they are great.
    n3oAcid24 = 01' Galant I4
    Member
    08-08-2007
    151
    Quote Originally Posted by n3oAcid24
    Cool!!! You know how much more power they get u if not it's aight.
    04-13-2005
    Chicago
    1,945
    Quote Originally Posted by 7GProject_4G64
    well the specs said something like 15-20hp. i installed the headers and a cat-back at the same time so i really couldnt tell you about the headers alone. just to let you know, i am very satisfied with them and if you have the cash to buy them, i said do it.
    Member
    08-08-2007
    151
    What kind of cat-back do you have? or did you costomize it yourself?
    04-13-2005
    Chicago
    1,945
    Megan Drift Spec its called.
    Member
    08-08-2007
    151
    Do you still have the site where you bought it from?
    04-13-2005
    Chicago
    1,945
    yea..... over on www.wesellcarparts.com good place to buy parts. bought a few things from him already.. :D
    Member
    08-08-2007
    151
    was it this one that you bought?
    http://www.wesellcarparts.com/store/...idproduct=3107
    04-13-2005
    Chicago
    1,945
    i bought something else since i have the 8G and you have the 7G man. that will fit your car if you get it extended about 10".
    Member
    08-08-2007
    151
    aight cool. where should I get the extra pipe from Home Depot?
    04-13-2005
    Chicago
    1,945
    you are going to install it yourself? if so,just take it to a muffler shop and have them weld it on and then install it. if you are going to go to a shop and have it down, just let them know that it needs extending.
    Member
    08-08-2007
    151
    [quote:0ceb84f0e1="n3oAcid24"]i have the RPW headers on my car. they are great.
    you are going to install it yourself? if so,just take it to a muffler shop and have them weld it on and then install it. if you are going to go to a shop and have it down, just let them know that it needs extending.[/quote:0ceb84f0e1]
    I guess I'll just do that instead it'll be easier but costly.
    hey just came across this post,i have a set of rpw headers that I purchased from proto a few months back. pm me if interested.
    Nobody built like u, u desighn ur self.
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
    [quote:fdd0a03ce4="7GProject_4G64"][quote:fdd0a03ce4="n3oAcid24"]i have the RPW headers on my car. they are great.
    you are going to install it yourself? if so,just take it to a muffler shop and have them weld it on and then install it. if you are going to go to a shop and have it down, just let them know that it needs extending.[/quote:fdd0a03ce4]
    I guess I'll just do that instead it'll be easier but costly.[/quote:fdd0a03ce4]
    Holy Quotes Batman!!!!!!!!
    222whp/250wtq
