Thread: Engine Shaking
Showing results 1 to 2 of 2
    Member
    08-08-2007
    Minneapolis, MN 55407
    151
    Engine Shaking
    At times when I start my car the engines shakes while in parked and when I am at a full stop. At times it does that but not very often my. My car is a 7G 95 Galant ES Auto. What should I do to make it stop shaking?
    sounds like your tanny mounts are bad. go under your hood, and look at the mounts and check for any tears or loose bolts
