View Poll Results: Enbgine bay wire loom color
Voters
41. You may not vote on this poll
  • All Black
    26 63.41%
  • All Red
    3 7.32%
  • Red for 2g / Black for 7g
    12 29.27%
Thread: Engine swap under way
Page 1 of 8 12345 ... LastLast
Showing results 1 to 20 of 145
    Kansas City, MO
    1,244
    Engine swap Done, now i just have to clean up some things
    finally i've had the time to do something i should have done over a year ago.
    atta boy
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    bout time!!!!!!! 8) enjoy the swap
    Yay the fun has started. Keep the thread updated!
    07-20-2003
    Orlando, FL
    3,169
    Thats my man!
    What are you going to do with the old 4G64? :?
    What engine is going in?
    8G_GTZ
    Quote Originally Posted by Strizi81
    LS1 350.....................
    or a 4G63T from an Eclipse
    05-25-2006
    New York City
    1,028
    Sweet bro....Keep up the good work
    2000 Galant ES = Daily Driver
    Kansas City, MO
    1,244
    The current sub-project, fabricating a 7g turbo wire harness :smt100 :smt073
    The 2g donor harness
    a few parts that will need to be transplanted.
    The OBD2 7g harness that i "pick n pulled" for $18 8)
    Kansas City, MO
    1,244
    oh. and the most important item...
    10-24-2003
    1,432
    Are you still planning on staying with the 14b. If so I've got a friend thats got a couple of extra's if you need them.
    www.gooichimotorsports.com
    Kansas City, MO
    1,244
    yeah, i'm just gonna start with that turbo for now, then when everything is in, ok, and i have a few other things to monitor and tune the set up, i'll go bigger. but i'd be interested in hearing about these "extra's"
    that motor looks clean as hell! rebuilt?
    Jigz-TGCIL Sosick Motorsports
    10-24-2003
    1,432
    Quote Originally Posted by Blue Ice
    He builds eclipses, he has 3 of them that arent being used.
    Kansas City, MO
    1,244
    Quote Originally Posted by 4g63lover
    More or less rebuilt, cleaned up the intake and exhaust ports, painted the exhaust mani with 1200 degree paint (hopefully it'll hold) repainted the valve cover, need to paint the intake mani. various replacement parts, metal head gasket, 4 layer exhaust gasket, HKS cams 264/272, Crower springs and spring seats (ported 2g head, cams, and springs thanks to Sinsere) not pictured Fidanza Cam gears,
    1200 isn't going to cut it.
    less all you plan to do is idle that engine.
    Damn how did I miss this thread. :evil: Congrats and good luck on the swap, we need a few more turbo 7g's around here.
    222whp/250wtq
    04-25-2007
    727
    Dam BLue Ice, I knew your were coming back strong but WOW.....
    If you get the chance Iam sure other members would benefit from a write up on how to rewire the 7g harness... Just curious what year galant did you pull the harness from as well as the eclipse?
    Kansas City, MO
    1,244
    Quote Originally Posted by phizzalot
    95 7g, but i check to make sure there were 4 plugs to the ecu 4=obd2, and not sure about the 2g wire harness, but 95 - 99 will be obd2. AND i also figured how to get the factory crimped wire connector out of the plug, so you can transfer the entier wire from one harness to the next without cutting.
    But today i didn't mess with the harnesses, i chose to wrench in the garage instead. got the cam gears on, timing belt, a/c unit, engine mount, belt cover on the new motor. Then, the tranny, and clutch plate off the old motor. Tomorrow i'll get new belts, and hoses.
    01-24-2005
    DFW/Stillwater
    2,752
    damn that looks like fun. i know my way around wires but that wiring harness looks scary
