Thread: Problems w/ UR G
Showing results 21 to 40 of 48
    01-07-2006
    707
    Having slotted and drilled rotors with ceramic pads helps a whole lot. I felt a difference in stop power when I installed mines, I highly suggest them Divinity
    Quote Originally Posted by Divinity
    Glove box rattles when going over 70.
    https://thegalantcenter.net/forum/vi...box+rattle+fix
    There is a fix for that. 8)
    Experienced TGC Member Divinity's Avatar
    05-01-2007
    Jacksonville, FL
    1,281
    Quote Originally Posted by Koncept
    Yeah i know... I'm just too lazy to do it, lol It only happened once or twice.
    DNS, I'll keep the ceramic pads in mind ;) Thanx
    ~Lady Driven~
    Last owner had the car for 5 years, and he said he hadn't had any problems with the car. just the timing belt which was changed at 55k miles and brakes and stuff like that.. stuff I've gone through.. my Steering Wheel Pump Broke, got it replaced. working now. drivers bearing went, was changed. 3 out of 4 shocks .. (changed all 4) this is maybe just normal after 6 years. And then well, lifters are getting annoying but that's maybe just normal (4G63) that's it I think
    When I turn on my front window defroster or turn the temp up to heat, my car makes clicking/clucking noises for about a minute then stops.... just happened tonight.
    Besides the sunroof getting stuck, the driver side window takes a bit to come up, looks like it's scraped on the outside. A/C takes forever to cool. Glove box rattles when going over 70. I have this God awful squeak when my windshield wipers are running, it has to be pouring down raining in order for my wipers not to squeak. Rain-X helps with that problem. I am in need of an oil change, alignment, and I'm not feeling too comfortable with my brakes (Planning on getting drilled/slotted rotors, good set of pads and rear drum to disk conversion soon)
    Other than that everything is pretty cool. 54,000 miles. I'm pretty sure I'll find something else now, lol.
    When I turn on my front window defroster or turn the temp up to heat, my car makes clicking/clucking noises for about a minute then stops. x 2..
    I had to replace the harmonic balancer.. other than that just routine stuff.
    fuel lid stayed in my hand last night... embarrassing lol
    my car has been good to me for the past 3 yrs + 22k miles.
    1. Clogged AC evaporator drain 2x
    2. Front sway bar link snapped somewhow. I think I take turns too hard
    04-13-2005
    Schaumburg, IL
    1,455
    lets see....
    the fuel door is the worst design ever I broke mine within week or so after I got my car and the glove compartment just opens automatic when hit a bump...
    thats it everything is fine so far...
    oh and the center speaker is no good why is that there? really odd place
    also you cant make U turn...
    Experienced TGC Member XxGiRLaNT06xX's Avatar
    05-24-2006
    Staten Island, NY
    1,995
    I've had a prob with my radio. It wouldn't play any sound and if any sound came out it was static. Had to replace the stock amp.
    Condensation on the passenger side (windows and rug)
    Check engine light 3x
    once at 1200 miles, 3300 and again at 4000
    All of this before 5,000 miles
    2011 Ibis White Audi S4
    *When you turn your car on ... does it return the favor?*
    The thread got big fast because Ally is the bomb lol.
    I had to replace the rear main seal at 61,000 miles. I called up the dealer and they still covered it under warranty. I gave the service manager $100 for covering it because they originally quoted me a ridiculous amount to fix it.
    Love,
    Matt
    Quote Originally Posted by furiousgtz
    lets see....
    ...and the glove compartment just opens automatic when hit a bump...
    hehe, I'm so used to these by now, I comletely forgot about them
    Its hard to fill up my gas tank ( the handle on the pump nozzle pops back when i try use full pressure every time)
    when i turn left, while (lightly) accelerating, there is a grinding noise somewhere in the engine compart.
    when i turn in wet conditions, the steering wheel locks up ( very rare now), since i got belts n stuff replaced
    thermostat went at 112000 causing my engine to overheat (mabye natural wear n tear?)
    passenger seat squeaks when no one is sitting in it
    car didnt come w/keyless entry remote
    115000miles and everything else is still perfect though
    Experienced TGC Member rez887's Avatar
    06-10-2005
    Dallas
    1,236
    squeaking glove box
    shaking steering wheel on the speed over 75mph
    This is right for all 8gs: Upper radiator hose leaking and needs a better clamp (it'll happen on all 8gs I'm 10000% positive
    Quote Originally Posted by Drucru22
    wth? that sounds REALLY bad dude. what do you mean by "locks up"? like the steering gets very heavy, or does the car completely stop responding to steering input?
    Quote Originally Posted by stolenstapler86
    yea, when i hit puddles or standing water while turning, the steering wheel would completely lock up, absolutely no motion AT ALL... but once i got my belts replaced, and i hit standing water, the steering just gets a lil heavy until the belt catches. this happened years ago tho like two times
    yeah I was gonna say, if that was current i'd be kinda worried. that sounds beyond dangerous. glad the belt change fixed it.
    on to my problems:
    Winking left headlight caused by melted socket (repaired, twice actually; second time I used a high temperature socket and it seems to be holding)
    broken glove box. the handle and lock cylinder fell apart a while back when my girlfriend went to get some tissues. remains unfixed.
    hissing/cracking stereo. fixed; replaced stock non-infinity sound system with pioneer speakers and kenwood headunit. sounds great.
    Horrendous vibration while in gear at idle. unfixed, I don't know what causes it but I suspect transmission mounts. goes away at any speed above stationary.
    there's more, mostly little annoyances, but that's the major ones.
    seems like more and more people are getting dash cracks. Protect it with dash cover plz
  19. #39
    -glove box rattle, never got around fixing it
    honeslty this being my 1st mitsu i really never had any major problems with this car, they are belt well
    00 Galant ES Turbo/5-Speed
    13 GTR
  20. #40
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by IceDouTGaLanT
    same here, i never checked it yet either. probably cuz i have so much stuff sitting in it :(
    run1206's Rear Disc Tutorial
