The 7G and up all use 134a like all newer cars since it is much safer for the environment.
I don't remember seeing too many guages built in to measure the pressure. If anything you use a guage available in most HVAC areas or one that comes with the A/C recharge kit. You attach the guage to the low side with the car running and A/C maxed and get a pressure reading. Full is around 45 PSI, the amount of refrigerant needed is labeled on the hood.
