Have you replaved anything under the hood/ car? I replaced the header and cat and all and some how I have a loose washer under my driver side floor board.
Whenever I rev up the engine and let off the pedal it rattles like it's smacking on something. At first I thought it was the catalytic converter but then I thought that it would make the sound while the car was revving so I ruled it out...but I haven't tried to tap it yet. Think this is anything I should be concerned about? It's not a light tapping sound either, it's a full blown "kling kling" sound.
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
have u check out ur exhaust system like maybe a loose bolt or a heat shield rubbing somethere?
We discovered was it was...when we revved the downpipe and exhaust flexes away from the front heat shield but once we let off it swings into it. Can't wait till I get my headers...hopefully all of my exhaust related problems go away.
NO.....they will be just begining
C.J. Cameron
RETIRED TUNER!!!!
"Keeping it Simple"
