Thread: Kia/Hyundai DOHC Head Swap
Showing results 1 to 20 of 31
    07-16-2006
    Cocoa, Florida
    791
    ok I'm really thinking of doing a Kia/Hyundai head swap, i was reading and i got to this page thing it said i needed at least 1 adjustable cam gear? is that really needed? Also would i have to do anything to the head or can i just slap it on and put the right size belt on it and start it up, EcU? can someone tell me in like description on how to do this? I do my research but i never find anything.
    Thanks, Duh2150
    08-06-2005
    Long beach/ guam
    1,585
    try club3g bro. goodluck.
    08-08-2004
    Las Vegas
    2,099
    lookup a member named flashbluers on club3g.com for a full parts list
    i'm doing the head swap now its actually pretty simple my head and block are at the machine shop now
    all aftermarket evo valvetrain components will work with the kia/sonata head
    the evo valve cover does not fit on the kia/sonata head
    the adjustable cam gear is a must... when lining up the timing marks if you dont have an adjustable gear you will not be able to set the timing correctly
    the dohc will run fine on the stock ecu
    you need a timing belt belt from a 94 dohc galant gs
    you need an evo/outlander tb the kia/sonata one will not work... iac motors are different
    the 3g guys say the kia intake manifold will not fit but they have less space between the motor and the firewall then we do so when i install mine i was test fit it
    any other questions just post them and i'll do my best to help you out until i finish my tutorial
    01-07-2006
    707
    Quote Originally Posted by underated
    Good information underated. I think this is what he needed to know. He's trying to get my dohc head and I was trying to answer as much a I could. Thanks!
    08-08-2004
    Las Vegas
    2,099
    its no problem i'm glad i can help
    nothing towards you milo its is better to point someone in the right direction then to give wrong info but everyone says to go over to club3g for stuff i just want there to be some info here too lol
    08-04-2003
    NY
    4,344
    +1
    Also in regards to that adjustable cam gear, you only need one, but you cant use the timing marks on the adjustable cam gear itself to set it correctly. I hope I can explain this in words in a way that is understandable
    Since the 4G64 block is slightly taller than the EVO block, and the EVO cam gears are made for an EVO, when you install the belt, if you leave the adj cam gear zero'd out and the stock cam gear both lined up with the factory timing marks, when you go to install the belt, it wont fit. It all has to do with the gear/belt tooth spacing and nothing to do with retarding or advancing timing. The only reason you need the adjustable gear is to take the slack out of the belt between the two gears. I think in total mine came out to the gears retarded -7 degrees, that was the setting needed to remove the slack.
    Here is what you do, if you look at the cam gear, there is a dowel pin in the gear that the cam goes into, first make sure your using the one labeled "EVO" because most manufacturers are selling DSM gears for the EVO with an added hole because they dont want to redesign the whole thing. The that dowel pin itself is straight up at 12 O'clock, that is the TDC for the cam. So what I did was I set the non adjustable cam gear just using the timing marks and then with the adjustable gear bolts loosened so it adjusts freely, I set it by looking at the dowel pin and lining that up with the timing mark (on the EVO's the timing marks are slightly leaned outward from 12 O'clock but its REALLY close) then once I had this set, I held the cam using a wrench on the bolt and slid the belt over the gear. Now since the adjustable gear is loose, just pull down on the belt firmly and it will take the slack out between the gears, now tighten down the adjustment bolts. With that done, go ahead and take the T belt back off, because you already have the spacing figured out and then set the timing like you normally would according tot he factory tech manual. Dont stress yourself if your timing is off a degree or two either way on the adjustable cam gear side, you need to be off like 4 degrees or better to start bending valves, once you get on the dyno you can fine tune that cam gear. Make sure you put the adjustable cam on the intake cam too, its just easier that way and if you ever wanted to make real adjustments, thats the cam you want to adjust.
    99' Galant ES
    4G64/63T
    AEM EMS
    07-16-2006
    Cocoa, Florida
    791
    why would i gotta change the tb?? im doing a head swap not a mani swap, so the cam gear is needed.. thanks yall thats all my questions right now
    08-04-2003
    NY
    4,344
    right there is your reason
    IAC means Idle Air Control. So what Underated is saying is that the motors are different which means it wont be plug and play if you try to use the Hyundai ones and further more if they are a different type motor in regards to signal, resistance, etc, the factory ECU wont be able to control it even if you did re-wire it.
    99' Galant ES
    4G64/63T
    AEM EMS
    08-08-2004
    Las Vegas
    2,099
    Quote Originally Posted by duh2150
    the iac motors are different and you are doing a head swap but thats not all your doing... with the dohc you cant use the stock intake manifold. the evo manifold works forsure as you can see from stewi and cali's cars... the kia/sonata manifold has the same exact bolt pattern but im not sure of it fits between the engine and the fire wall or under the hood
    you will be changing the water neck on the back of the block
    the thermostat housing will have to be from the kia/sonata you cannot use the evo or the galant one
    you need to tap the thermostat housing for the water temp sender that shows the hot/cold on the guage cluster... when using the evo head you dont need to do this because you have to use the evo thermostat housing and that one has a place for the sender
    you also have to change the reluctor on the exhaust camshaft to an evo one if you are going to use the stock sonata cams... the reluctor is what the camshaft position sensor reads to determine proper timing
    there is more but what stewi and I have posted above is most of the main things you will need to do
    01-07-2006
    707
    So the stock ECU can run the DOHC swap with no problem? That is great. I was wondering if you have to run another ECM/ECU program to keep up with the new air and fuel ratios. Very nice
    08-08-2004
    Las Vegas
    2,099
    nope flash proved it is not necessary which is really good news lol... to get the best performance as with everything you will need some type of engine management setup
    08-06-2005
    Long beach/ guam
    1,585
    non taken bro. it's all good. but you gots some good info though. i like that!!! double thanks!
    07-16-2006
    Cocoa, Florida
    791
    "you need an evo/outlander tb the kia/sonata one will not work... iac motors are different"
    i still dont understand why id have to change the tb, doesnt the outlander have the same 2.4l as the 2.4l we got? soo.. wouldnt that mean the same tb? are there tb bigger or what? plus i wasnt gonig ot put a kia/sonata tb in it.. the connections wouldnt work most likely,.. soo can someone tell me the differnce between 2.4l outlander tb and a 2.4l galant tb?
    01-07-2006
    707
    The outlander has a different intake manifold then our crappy 4g64 intake manifolds. They do not have the same TB.
    07-16-2006
    Cocoa, Florida
    791
    so id need the tb and the mani?
    01-07-2006
    707
    If you are using the DOHC head, you need the tb, the intake manifold will not fit, so you either have to get the Evo 8 manifold or a kia manifold.
    08-08-2004
    Las Vegas
    2,099
    galant tb = 54mm
    evo tb = 60mm no cruise control
    outlander tb = 60mm w/ cruise control
    the evo and outlander tb's have the hookup for the throttle cable on the front side of the tb... the galant has the hookup on the rear (firewall side)
    so the intake manifold for the evo/kia/sonata intake manifold have the bracket for the throttle cable on the front side of the manifold (engine side)
    you could use the galant tb but you would have to rig up a new throttle cable bracket but the bore of the tb is smaller... the whole reason for the head swap is better performance why skimp out on a better tb if one is easily available
    07-16-2006
    Cocoa, Florida
    791
    oh lol know i know its a 60mm and now i know im gonna get more power outa doing it i dont care lol i thought they all where 54mm or whatever like the galant well at least the outlander one i thoguth had a 54mm becasue of the same engine and all, ill get evo tb becasue i dont got cruise control, i hope it dont cost that much, and il lget the outlander mani, becasue its casted and i could turbo it later :) thats kinda good news just more $$$ then i was wanting to do, this mod should be kinda easy to do, but time consuming, and the hardest part should be the belt thingy, im kinda afraid lol ill get a knotch wrong and blow it up or somthing
    01-07-2006
    707
    The outlander mani doesn't fit on the DOHC head, either the evo 8 or the kia manifold, then you can mate that up with either the 60mm evo tb or the outlander 60mm tb
    07-16-2006
    Cocoa, Florida
    791
    so i got no problem with that,.. jsut longer waiting time, so would i have to change otu the maf sensor too??
