Thread: Step two: Turbo time
Page 2 of 2 FirstFirst 12
Showing results 21 to 22 of 22
    if its the water lines, and they are the parts that are of the turbo(not the side that interfaces with the turbo) then grind off the bano fitting and flare the edges, now you have cheap lines that you can slide flex coolant hose over and send to yoru water neck.
    be sure that its not the oil supply line thats on TOP of the cartridge
    Well I kinda forgot to update this thread, I got my maf translator in and was going over the install. I di install the gm maf already.
    Also a current engine bay pic
