someone should write up a tutorial cause i want to replace mine as well
I will be getting a set of OEM Fogs real soon...$20 for the pair + shipping!
I was wondering, how much of a pain will these be to put in? I should only have to bolt them in and wire my afermarket wiring to the OEMs right? They use the same bulbs I believe. Anyone have any insight?
I guess if no one knows, I'll have to do it! Keep an eye out
Personally I'm using aftermarket fogs and my car didn't have fogs stock. It's pretty straight forward for stock imo. If you lay down and look up into the slots designated fo r the oem fogs you'll see 2 predrilled holes already there. I forgot what size screw or bolt fits there. Haven't fooled with mine for a while. Wiring is pretty much up to you.
You can attempt to replicate the stock wiring or tap power directly from the battery or whatever. Have it triggered by the headlights or a switch. Not too difficult to get OEM on imo.
RIP
1995 7G 4G64 / 63T DOHC Turbo
Part Out Coming Soon
In search of 2G 3000GT VR4
Daily driving
Dat '08 Cobalt Coupe
if you have the pigtails coming out form the back of the factory fogs you should be fine. if you want to make things easy you could just use the wiring you have already ran for the aftermarket fogs. they're both a 12v setup so you should be fine.
They are a cinch to install, as long as you have the mounting brackets its a 1,2, thing.
You will need to look in the engine bay for the wire harness to plug them up and then you also need a fog relay for the fuse box in the hood and your done. took me 15 minutes.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
Well I have aftermarkets now....wired to a switch. I am just gonna mount the OEMs to the same wiring and switch. I think it will just be a matter of me mounting them... everything else is done really
true that.
O didn't realize that :oops: . You're good to go than , I have diagrams to the setup of the fogs. Post it when I get home if needed.
RIP
Daily driving
Originally Posted by bronxbombr
Ok...so mounting brackets....? My car did not come with fogs initially so do I need OEM brackets? I would assume yes How much and how long to get em?
i have to look around to see if i have any spare brackets. I know i do but dont know where they are in the garage. Will look today after work.
Hey were you buying yours from Just want to know cause I'm looking for some OEM Fog Lights too.Originally Posted by evil-G-nius
and to think, after all my for sale posts where i have had way over 3 or 4 sets of fog lights and stuff.............Now you guys decide you need em
When I needed em you said you could only find one! I asked your ass before! LOLOriginally Posted by bronxbombr
you asked me for the foglights, not the brackets dude.
I know...thats what I am saying! YOU said foglights...and stuff. Before, I asked for fogs...you didnt have any! LOLOriginally Posted by bronxbombr
So how bout those brackets? Any luck?
still looking, will let you know.
if my car didnt come with fogs are the wires for the factory fogs available in the housing somewhere tucked away in bumper ? or do i need to run my own wires
The short answer is yes there should be a factory harness tucked away somewhere. I won't be of much help because I never installed them but if you search around I know it has been posted before.
222whp/250wtq
The black things to the left of your steering wheel. Pop that entire thing out and in the back you should see the wires for power mirrors and fog harness already there. Not sure what exactly you have to run since the wires don't actually extend into the engine bay from what I noticed. Or maybe they do...didn't try too hard since I'm running my own wires.
RIP
Daily driving
