Member
is this engine for real?
can this be mounted in a 2003 galant es I4 2.4liters
http://www.japanpowerinc.com/engine_...tsubishi_4G63T
or maybe this??
because they come brand new only for $1500 dollars not sure if these are the engines everyone talks bout doin swaps in 8gs??
Just look at the way the intake/exhaust manifolds are oriented relative to the pulleys. No is the answer, BTW.
Look man it can work, yes it can but you better have a hole shit load of money to get this job done. Other wise no its no a really good idea to drop that in a 03 galant, everything is on the opposite side, complete diff engine, diff ecu, wiring, tranny. Everything is on the other side....so yes it can be but like I said your car ganna be sitting for a while. Just find an 02, 03 galant engine or eclipse rebuild it and turbo charge it. Or evo swap, you have a better chance doing that.
holy old post!
lol but yes galantfan88 you are correct
